Custom Drilled Aluminum pedal set for FC's
Old Nov 9, 2002 | 09:17 AM
Sled Driver's Avatar
The Anti-Prius
Now you can get a "True" custom Drilled Aluminum Pedal Set
(all four pedals)
for your FC.
Designed to fit without drilling, the gas & dead pedal bolt directly on using existing holes
Not some cheesy K-Mart pedal set that is a cast flat plate with bent tabs to hold it on.
These pedals follows the stock pedal profile & contour, so it will never "hang up" on your carpet & bind
https://www.rx7club.com/forum/showth...hreadid=127206
Uses aircraft hardware, stainless steel screws & self locking nuts. Will not loosen up or shift, EVER
Installs in minutes, includes all hardware & instructions
Go to......
https://www.rx7club.com/forum/showth...hreadid=131249
for more info
Old Nov 9, 2002 | 06:03 PM
darkside7's Avatar
nice. i can vouch for his work. i have most of the pedals and passenger foot rest. excellent craftmanship.
Old Nov 9, 2002 | 06:15 PM
faye x7's Avatar
brilliantly stupid
If I had a job..yes...now...no. -_-
Old Nov 10, 2002 | 05:29 AM
Aico's Avatar
Will you make FB pedal kits in the future?
Old Nov 10, 2002 | 08:59 PM
The Anti-Prius
If I get enough requests, anything is posible.
First I will need to purchase a complete FB pedal set to use as a guide.
Then find some free time to develope them.
I'll keep you posted........, but don't hold your breath
Old Nov 13, 2002 | 10:26 PM
The Anti-Prius
Installed pic
courtesy of "knight1976"
Thanks,
astrum
24
Nov 15, 2017 08:44 AM
Jun 26, 2016 10:21 AM
