Need intake sug.
Old Aug 1, 2001 | 11:23 PM
OneBadRx7's Avatar
Lucky
Unhappy
Well I have the Apexi super intake but from looking around I feel as though the Crooked Willow or M2 be about the best out there. They have concealed boxes for the air and that seems to be the way to go. Oh and if anyone out there wants to trade my like new Apexi for their Pettit intake I am willing since I am trying to do up an all Pettit car, thanks guys,
Old Aug 1, 2001 | 11:59 PM
Mr. Mahtab's Avatar
Air Box
Well Apexi and HKS AND Airlynx and all that other stuff are all foam style (more propriotary to those intake/intercooler combos) And they look cool if you live in a cooler area..........But if you live in the heat...that's pretty hot air going in that intake. Thus the "cold air box" is around. And I live in the California heat!
My opinions:
M2: Carbon Fiber, over engineered (thats not a bad thing) inexpesive (there is no way in hell I could make this thing for $485) 2 K+N's mounted I bought it and I am very pleased. Thank you sir, can I have another!
Pettit O.K. I guess....it way over priced for a couple K+N air filters and a piece of sheet aluminum with a chunk of foam. It should cost $179 max buts it's a lot more. But that's Pettits way....to charge you up!
N Tech: Like the Pettit, but better thught out and made, hence it has angles to seal the area (see their site)
But if you can afford it .........M2
Old Aug 2, 2001 | 11:16 AM
Johnny's Avatar
OG
I have the newer rx7fashion box (very sim to m2's)
and with a mazdacomp radiator you have to cut off the flap on one side of the rad...this would have to be done with m2's box as well.
Old Aug 2, 2001 | 11:49 AM
Agreed M2 is very nice. I traded my N-Tech for one and love it. The N-Tech is a great intake.
Yes you need to modify (ie cut the flap) of the Mazda comp radiator for all of the intakes that use the side of the radiator for fresh air. M2, Pettit, N-tech, RX7Fashion, CWR, etc
Old Aug 2, 2001 | 12:00 PM
Brad's Avatar
dear baby jesus...
Forget all that, they all suck ***. Just go buy a T78 and all you have to do is slap a big *** K&N on it!!. Badaboom!
Old Aug 2, 2001 | 12:16 PM
Originally posted by OGstreetracer
How hard is it to install a radiator?
Not too difficult if you have already replaced intake and IC. You need to remove both of these, and oh yeah the battery box too. With aftermarket IC, the intercooler is a snap to remove. Removing the stock IC, ducting, intake, AST and battery box are all easy to do just time consuming.
Once you have these out you need to remove the fans and drain the coolant.
-Mark
Old Aug 2, 2001 | 05:41 PM
Jetlag's Avatar
Drop in K&N filter and a modded stock airbox is best. Not as much heat transfer as other aftermarket intake. Sure, it's not as cool looking. But the best.
Old Aug 2, 2001 | 05:49 PM
Agreed that this setup is probably just as efficient as aftermarket. The main reason I went to after market is:
1. Allow more room for SMIC
2. Free up space behind the radiator for more efficient cooling
3. Looks cool
Old Aug 2, 2001 | 05:57 PM
fluxen's Avatar
I have to admit, the only thing that got me to remove my modded stock box was the fact it wouldn't fit under my vented hood. Run some air hoses from the front of the car to the stock box, seal the commond duct between the IC and airbox, and you've got a great CAI!
turbovr6's Avatar
https://www.rx7club.com/vforums/show...threadid=12880
