ACV / Haltech / Assembled Vehicle question
Old Nov 5, 2002 | 11:18 PM
robmk2's Avatar
Originally on haltech forum - maybe will be better here. Sorry for the duplication. Anyway, help please.....
As a background I am scratch-building a lotus 7 look-alike with a 13b-RE JDM engine. (picture of car can be seen attached to my first post last night in the haltech section - she's not an RX but I love her anyway). It will be titled as an "assembled" vehicle here in Texas – this means the car will have to pass a full safety inspection - including emissions both sniff and visual (I think) at a designated safety inspection location. (Conroe?) With luck it should be ready for this in a couple of months time. Chassis / body / suspension etc done but for finishing.
The car will have no AC or PS or roof or any other fancy stuff... and I have already converted to full non-sequential (for simplicity) and will be using a manual boost control set-up. The "Rats nest" and solenoids are all history. The car will only weigh around 1200 lbs so I will not lack performance I am sure.
The RE engine does not have EGR as it is a JDM (Thanks Gary!). I am using a side pipe exhaust consisting of a small SS cat and muffler. Also, PCV is no problem as I can figure that out on my own along with the charcoal cannister deal (although the purge is history!).
I understand from previous posts that I can use one of the Haltec PWM outputs to switch the airpump clutch on at idle and off at say 3500 RPM I guess, but I am confused as to how to make the Haltech control the other ACV functions, and indeed which I need to use – and when. I guess I can use the other PWM outputs in a similar way as I should have some available. I have an E6K.
Here goes with the questions.........What ACV bits (i.e. Port, Split, Relief?) do I need to have operating when, and under what engine conditions. I think i need the port air (to manifold) to work at idle and the split air (under load?) up to 3500 RPM but I'm not sure........On the RE's ACV there are two 1” pipes…. I guess one is from the Air pump and one is relief. There is just one electrical solenoid valve in the body of the RE's ACV that I think controls the split air, and there is also one vacuum inlet that closes the lower one of the two 1” pipes when under vacuum. I think this does the relieving.???
Hope this is clear to someone with some savvy! I checked but couldn't find much in the archives.……..Thanks in advance for any help
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
