FMIC overheat?
Old Nov 4, 2002 | 01:45 PM
FMIC overheat?
I hear that a FMIC is not good due to it restricting airflow to the radiator..... So which is better a FMIC or a large IC that mounts in the stock location? Thanks for your patients guys.
Old Nov 4, 2002 | 02:03 PM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
My friend has an hks type s fmic on his single turbo FD and it does not overheat at all. He does have the fluidyne radiator upgrade though.
Old Nov 4, 2002 | 02:14 PM
RX7Elmo's Avatar
Just do a search for "FMIC SMIC" and you'll find tons of info on the pros/cons for both.
FMIC is good for street driving/dragging, but not good for road racing due to th extended load. I would love for someone to prove me wrong in that an FMIC can be used for track days/road racing.
With the FMIC, just make sure the radiator still gets good flow and do the fan mod, also get a water temp gauge.
Overall, if you had/have overheating issues before, it won't get any better after the FMIC install.
Danny
Old Nov 4, 2002 | 04:27 PM
efiniracing's Avatar
Just get a good aftermarket radiator and you won't have to worry about it. I have the XS Engineering front mount, and the Fluidine radiator w/ proline water wetter. I have no temp. problems, even in the summer time pushing 15lbs of boost. However before I got the radiator, I could see my water temp. going up when I was sitting in traffic.
Old Nov 27, 2002 | 08:14 AM
SleepR1's Avatar
This is a simplistic response...do you road race your FD???
Old Nov 27, 2002 | 09:53 AM
twinturboteddy's Avatar
Grumpy Lurker
FD with stock IC and stock radiator
Cruising 89C-92C
Hard Driving 95C-98C
FD with FMIC and stock radiator(stock location)
Cruising 92C-96C
hard Driving 98C-103C
Old Nov 27, 2002 | 11:18 AM
actionhank's Avatar
well TTT, do you have any numbers that have a FMIC and a upgraded radiator? I would like to see that too.
Old Nov 27, 2002 | 01:04 PM
bkapold@aol.com's Avatar
I have a Spearco 27 x 7.5x 3.5" FMIC on a 91 TII w/ T60-1 turbo ran by a Wolf EMS ecu....and when I had my stock radiator my car was running about 95c-103C on semi hard driving @ 15-20psi. I just finished installing a Griffin Aluminum radiator and my temps were 81-85C....You gotta get rid of those stock radiators...thats my .02....
The Griffin radiator was 189.00 in the Summit catalog and I tig'd some brackets on and it works and looks great
Old Nov 28, 2002 | 03:40 AM
Chronos's Avatar
take a look at this thread I posted in...
https://www.rx7club.com/forum/showth...hreadid=132608
The1Sun
Sep 7, 2015 10:21 PM
