what does it mean when oil drips between your cat and catback
Old Jul 31, 2001 | 11:49 PM
LT1-7's Avatar
John
I don't have the catback to the cat tighten on too tight so I have an exhaust leak. I only parked the car for about 14hrs and when I went to start it up, smoke came out like crazy. Then when the some calmed down a bit I revved it and saw that drips of oil came out from the gasket of the catback. What does that mean? Is it the turbos? It dripped about the size of a 3" diameter
How else can oil get in the exhaust besides the turbos?
Old Aug 1, 2001 | 12:29 AM
Donovan's Avatar
Hi sir
It's possible your just seeing condensed water that collects in the exaust overnight leaking out. It would take a SERIOUS oil leek to produce drips from the exaust. It could be coolant however which is bad so keep an eye on the level.
Old Aug 1, 2001 | 02:25 AM
LT1-7's Avatar
John
no, it's oil. Black and oily
Old Aug 1, 2001 | 05:56 PM
Donovan's Avatar
Hi sir
Remember that water from the exaust will be black from the soot in the pipes however if you are leaking that much oil it is BAD
msilvia
28
Apr 14, 2016 12:58 PM
Snoopy FD
Dec 8, 2015 01:45 PM
HDA
Nov 3, 2015 03:49 PM
Dripping Springs
Aug 28, 2015 09:55 AM
