engine light came on today
Old Jul 31, 2001 | 08:51 PM
rx7grl's Avatar
It was flickering on and off and as it flicked the rpms would drop and then go up, and i would hear the engine kind of making a thump sound. I turned the car off and on again and it still did it. I had been driving it for about 30 minutes when it started. But after I let it sit for about 10 minutes it didn't do it anymore. What the hell. The engine was replaced about 15-20,000 miles ago. It's a 90 GTU. Could this be related to my exhause leak or the small backfires i get as the rpms go idle up and down? Huh? Help? Please?
Old Jul 31, 2001 | 10:50 PM
Taranis's Avatar
Maybe a Throttle Position Sensor? Sounds like the computer is searching for the right air/fuel mixture when it's idling.
I know from talking to Atkins Rotary about a similar problem, the computer tries to find optimal settings for the engine. If it can't it switches to a "default mode". That might explain why it did it one minute and not the next.
Have you replaced your plugs and wires recently? Might also be bad spark.
Just my .02 of wierd logic..
Old Aug 1, 2001 | 11:40 AM
Question Seat Belt Light Flicking?
Sorry; But now that we are in light flicking area I had to ask. My seatbelt light was flickering lastnight, it was flicking/beeping for almost a minute, then solid with one long beep? So i thought maybe it was cause my gas was really low; But can there be another reason why it happens? Even thou it did stop after putting gas I'm still curious why? Any experienses, opinions?
Thanks and sorry again........
Old Aug 1, 2001 | 09:14 PM
rx7grl's Avatar
hey so i have it figured out now that it does it when i let off the gas. I am going to try and change the plugs and hope that's it. I don't know when the last time they were changed was. Anyway, if anyone else has any ideas....
Old Aug 1, 2001 | 11:06 PM
cold solder joint prob maybe?
Kyo
Apr 13, 2019 09:24 AM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
gtcd
30
Aug 19, 2015 02:44 AM
