Will a HKS FD manifold fit FC?
Old Oct 29, 2002 | 05:31 PM
RacerXtreme7's Avatar
NASA geek
Will the HKS T04 Stainless divided tubular manifold fit on a FC? If not what mods will need to be done? Will just spacing it away further from the motor work?
I NEED A T04 STAINLESS DIVIDED MANIFOLD FOR MY FC!!!!
~Mike............
Old Oct 29, 2002 | 05:52 PM
13BAce's Avatar
On a long vacation
Yeah, if you use a spacer it should do ok. The main problem would be hitting the intake manifold. The RB 13B header flanges make good spacers.
Old Oct 29, 2002 | 08:53 PM
Big Al's Avatar
Yeah, the manifold will fit. But, you won't be able to fit a very large turbine housing onto it. It will hit the lower intake.
Old Oct 30, 2002 | 06:47 AM
jspecracer7's Avatar
1JZ powered
You may have to drill out the mounting holes a bit. The manifold I'm using came off an FC and it didn't mount up exactly due to the bolt holes so I took a grinder to the holes and opened them up a bit. Fits fine now....WITH the turbine. However, it was modified.
Old Oct 30, 2002 | 07:30 PM
NASA geek
Thanks for the info guys...
~Mike...............
Old Oct 30, 2002 | 08:27 PM
93 R1's Avatar
So... A FC manifold will fit an FD just by making the mounting holes bigger?
Old Nov 3, 2002 | 01:35 PM
fastrotaries's Avatar
W. TX chirpin Monkey
just a hair though, really not much.
kkev.7788
Sep 2, 2015 01:32 PM
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
