BAC valve?
Old Jul 31, 2001 | 01:18 PM
flak3r's Avatar
BAC valve?
In regards to the BAC valve, cant I just block is off?? and if I did.. what would this do?? retaining the stock ecu system
Old May 16, 2011 | 05:42 AM
oinesra's Avatar
You would have loss of idle control by the ecu.
Old May 16, 2011 | 09:54 AM
Aaron Cake's Avatar
Engine, Not Motor
I love it...
"I want to do something but have no idea why nor the consequences".
The BAC valve is used by the ECU to regulate the idle. Removing it and installing a blockoff plate is a downgrade to the car as you will now have to do silly things to keep it idling properly (like jacking up the idle to a higher RPM). There is absolutely no gain in any way, shape or form from removing the BAC valve. Period. Removal of the BAC valve for the purpose of removal of the BAC valve is idiotic and breaks the car.
So yeah, while you could just block it off, you don't want to.
Old May 16, 2011 | 10:15 AM
arghx's Avatar
rotorhead
there's really no point in taking it off unless you literally have a race car that is trailored
Old May 16, 2011 | 07:02 PM
chatchie's Avatar
If your looking to clean things up you can unbolt the coolant block from it and re-route the lines. The lines are there to keep it from freezing.
Old May 16, 2011 | 07:15 PM
nycgps's Avatar
PedoBear
when you remove it, you save yourself a holy-moly 4 lbs off the car !!! you can't beat that !!!
Old May 16, 2011 | 07:40 PM
SpikeDerailed's Avatar
This sh*t burns oil!
Attn any idiots reading this...^^^ he(nycgps) was being sarcastic you don't save 4lbs.
Old May 16, 2011 | 08:32 PM
nycgps's Avatar
PedoBear
I don't ?! OMG ! can I just take more random parts out cuz I swear my neighbor said so.
Old May 16, 2011 | 08:44 PM
Spirit-RE's Avatar
I'm running no bac right now(didn't have one on the manifold when I got it). Its stupid. Only way it idles is ~1200 and it sucks at returning to idle.
Rotafuzz
Sep 30, 2015 09:55 AM
