Newbie question "what is the ATF Treatment?"
Old Oct 26, 2002 | 08:17 PM
Jay Cee 69's Avatar
Newbie
Question Newbie question "what is the ATF Treatment?"
Hi boys and girls! im a newbie to this stuff and was wondering about a term i have read alot.... what is the atf treatment? what does it do? will it fix my rx-7 that blows smnoke? please reply A.S.A.P!!!! thanks!
Old Oct 26, 2002 | 08:35 PM
82transam's Avatar
Never Follow
You put a few ounces of Auto tranny fluid in each rotor and let it sit for a few days, turning the engine by hand every so often. Making sure to get all the apex seals coated. It will get rid of some of the carbon buildup in there and increase compression. I've never done it so I couldn't tell ya how well it works, but everything i've read indicates that it does work quite well. Good luck with it.
Old Oct 26, 2002 | 08:45 PM
ricola555's Avatar
Department of Alcohol Tobacco and Firearms.
Old Oct 26, 2002 | 08:49 PM
82transam's Avatar
Never Follow
I get the ATF in that comment, but wheres the D from?
Old Oct 26, 2002 | 10:11 PM
Jay Cee 69's Avatar
Newbie
do i have to turn it by hand? couldnt i just crank it over via the ignition? is there any tips about it that you can give me? feed back?
Old Oct 27, 2002 | 02:46 AM
Gatorgunner's Avatar
do a search for ATF treatment. Basically you disconnect the coils and pour automatic transmission fluid down the bores of the carb while a freind is giving it 1/2 gas and cranking for 5 seconds each time. i did it till i ran outta auto trans fluid. Let sit for 24-48 hours and start her up ( it will be difficult) and viola, Mt. St. Helens!
If i were you though i would do a search as you will find a step by step procedure somewhere
Old Oct 27, 2002 | 02:00 PM
cjf's Avatar
cjf
yeah, do a seach ..there si a lot of info on the subject...especially from one of the forum members ,DENNY, he has a lot of input in this regard...you can even PM him, he will help you if you have specific questions. But, there are a lot of links to this subject..." search, and ye shall find"....cjf
Old Oct 27, 2002 | 03:34 PM
Jay Cee 69's Avatar
Newbie
Hey thanks for the advice guys! i shall probabaly be back soon with some more first gen questions...lol later!
Old Oct 27, 2002 | 03:40 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
There is no "Department" of Alcohol, Tobacco, and Firearms. It's the BUREAU of Alcohol, Tobacco, and Firearms, BATF.
"Hello, BATF? What kind of Bourbon goes with an AK- 47?" -WG
Old Oct 27, 2002 | 03:44 PM
Wankelguy's Avatar
Whoops! Got so carried away being silly, I forgot to mention that Techron does a better job of cleaning out carbon deposits than ATF. Pretty much the same procedure as for using the ATF. You can leave it in for a week, and it will work great. -WG
Old Oct 27, 2002 | 05:42 PM
inittab's Avatar
I read your email
Or..... you could slowly pour a liter of water down the carb while it's warmed up and running. It's supposed to work well for de-carbonizing rotaries. Just thought I'd throw that out there.......
Old Oct 27, 2002 | 06:52 PM
82transam's Avatar
Never Follow
Water? your joking right?
Old Oct 27, 2002 | 09:23 PM
RacerX7fb's Avatar
paradox
I did that to my old Honduh Civic CVCC! It worked
Old Oct 27, 2002 | 09:45 PM
fatboy7's Avatar
Got Boost?
Just don't pour too quickly, water lock is not fun..... and you thought pinging is bad, water dosen't compress!!
Old Oct 28, 2002 | 03:14 PM
I used Marvel Mystery Oil, and it worked great.
Yeah, you COULD crank with the starter when doing it, but you will get this oil fog pumping out the spark plug holes that will coat everything in your engine compartment and everywhere else it lands. That being said, cranking with the starter probably coats the inside better.
Oh-yeah, yo uwant to have a new set of spark plugs on hand for afterwards. Keep your old set for future ATF treatments.
Be prepared for a very IMPRESSIVE amount of smoke coming out of your tailpipe when you start it up. Maybe starting it at nighttime is a better idea, so your neighbors don't call the fire dept.
Old Oct 28, 2002 | 06:17 PM
i got the fire dept called, by the time they showed up, it was all over, hehehehe fu--ing dumb *** neighbors
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
