Haltech ?'s about Crank Angle sensor & Oil metering pump with Haltech
Old Oct 26, 2002 | 05:41 AM
rx7superman's Avatar
Question ?'s about Crank Angle sensor & Oil metering pump with Haltech
Hi, I was hooking up the Haltech(3rd Gen) and noticed that I can't use the connector it came with for the crank angle sensors. So, I'm going to use the factory connectors but, what I need to know is which wires go to which connectors? Also, I was told you can't use the metering pump with the E6K......it could only be used with E11. Is this true?
Old Oct 26, 2002 | 09:21 AM
rxrotary2_7's Avatar
You can try to retro fit a mechanical OMP from say a n/a 87 rx7. You cant run the stock one w/ e6k. try to PM gmonson or search around, people have done it. You would use the cruise control cable to do this.
as far as CAS
Connections to Haltech:
NE Sensor:
Green (negative) : To Haltech "input B" input
Black (positive) : To Haltech "trigger" input
G sensor:
Red (negative) : To Haltech "input A" input
White (positive) : To Haltech "home" input
LunchboxSA22
37
Oct 26, 2015 10:53 AM
