side bumpers"what takes it off"
Old Oct 21, 2002 | 11:08 PM
rgus30's Avatar
hey all what is the best to use to take the black bumpers of the sides of a 82 rx7. I see that they are stuck on with some kinda glue?
thanks
Randy g
WA st
Old Oct 21, 2002 | 11:21 PM
RotorMotorDriver's Avatar
Seven Is Coming
Haha, Id love to know myself. I just under-took this project a couple days ago myself. I have done the rear quater panels with a fair amount of sucess. Ive just been pulling and peeling with my fingernails and a friends help. Its taken a LONG time just to do what I have so far.
~T.J.
(this side needs a little more washing, but it should come out ok)
Old Oct 21, 2002 | 11:26 PM
DJ!
is it the rubber kinda tape??? if it is hot boiling water! and your fingers or something wont hurt the paint!!
Old Oct 21, 2002 | 11:28 PM
Hyper4mance2k's Avatar
The Shadetree Project
damn i didn't know you could take off the molding and leave the side marker... did you have to cut it out? or does it just peel off around it???
Seven Is Coming
Oh yeah...DO NOT UNDER ANY CIRCUMSTANCES USE GASKET REMOVER!!! I have a bad fender (dented from an accident) that I use to test products that say "test on incinspicuous area" on. That way, if it screws anything up, the fender is so screwed it doesnt matter. Anyway, the gasket remover took the rubber off like a charm...But it also took the paint with it. I pulled the rubber off, and wiped it down with a shop rag. Suddenly, my shop rag was white, and the paint was REALLY thin where I just wiped it. Thin to the point you can see the metal through the paint. It didnt even soak in. It just sat there for maybe 20 seconds while I was working with it. Anyway, no loos cause as I said before, the fender is dented and the paint chipped so its rusted too. I planned on pulling it off, stripping it, and primering it until I can get a new one, along with a little section of my door where a door ding got out of control.
~T.J.
PS - The rubber stip is held on REALLY well in some areas, and on my bad fender it actually took paint chips off with it so it looks like there are rock chips or something. That could just be because the paint was messed on that fender anyway, I dont know. Fair warning .
Old Oct 21, 2002 | 11:30 PM
Seven Is Coming
Nope, the lights are seperate from it. It peels off right out and around them .
Its held on with a type of double sided tape.
Theres the cars body, a strip of tape, and then the rubber is stuck to the tape. Taking the rubber off is easy. Getting the tape off the body, ISINT.
~T.J.
Old Oct 21, 2002 | 11:33 PM
Seven Is Coming
Oh yeah, I just had a revalation...
I started this on my 83 GSL (shown above) because a section of mine came off of my 85 GSL all by itself when I had a leaking gas cap. Thats how I found out that its seperate from the lights. I also found out later when I pulled it off my 83 GSL that there are no body pins that hold it on anywhere. No holes to fill . Anyway, I would go around corners, the gas would slosh, leak out frum under the cap, and run down the side of my car. The gas took the rubber strip off in a matter of a day or two until I figured out that my cap was leaking and thats why I had gas marks down the side of my car. The gas doesnt seem to have affected the paint, so you may be able to use gas (or similar) to disolve the adhesive .
~T.J.
Old Oct 22, 2002 | 01:26 AM
rgus30's Avatar
thanks for the info NOW I hope it comes off good.
I will be repainting so I am not to worried about it. I was just worried about the body , if ya dented it or not while taking it off.
just dont need extra work LOL
thanks
randy G
WA st
Old Oct 22, 2002 | 08:12 AM
Pele's Avatar
Right near Malloy
Is there any way to flatten out the marker light? It looks like it stick out kinda far with the side moldings removed...
Perhaps side markers will fit form a different car?
Old Oct 22, 2002 | 08:49 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Its 3m double sided tape, you local auto paint supply store will have something for it. I bought some of it (forget the name) poured it on the top of the molding let it sit for a minute, and went pull , the whole thing came off w/o any trouble what so ever...
Like Ive said before proper tools , proper parts
Old Oct 22, 2002 | 10:44 AM
When i detailed we used to have to take stupis stuff people put on their trade ins all the time. and that tape comes off hella easy if you leave your car in the sun all day if its like 70+ that day or just use a heat gun or hair dryer.. will work mericals. or pinstripe remover would work great. its just a big eraser on a wheel you put it on an air tool and it spinns really fast its fun to fu(k around with just don't burn the paint
Old Oct 22, 2002 | 01:11 PM
82transam's Avatar
Never Follow
I've given this some thought too. They do look bad once the molding is gone. Anyone have any thoughts as to a possible donor car with flatter ones?
Old Oct 22, 2002 | 01:23 PM
exodus82's Avatar
Taking the side mouldings off looks soo gay.
leave them on.
Old Oct 22, 2002 | 01:31 PM
Pele's Avatar
Right near Malloy
leave them on.
That works too.
Old Oct 22, 2002 | 01:42 PM
lotsacars's Avatar
leave them on.
However, if you're going to repaint the car it would look a heck of a lot better if the paint went under them rather than up to them (ie. taping around them).
I'm goint to repaint mine in the spring and this is useful info as I'll be pulling stuff like this off to paint. Whether I'll put them back on has yet to be decided. Probably won't.
Old Nov 2, 2002 | 07:26 AM
Seven Is Coming
Has anyone priced new ones in the VB catalog? Almost makes you wanna sell your old ones hella expensive, lol. I could get rich doing that if people would really pay that much for them...Go to junk yard, remove, buy, re sell, repeate...
~T.J.
Old Nov 2, 2002 | 07:34 AM
MIKE-P-28's Avatar
~T.J.
Every wonder why they still have them in stock after so many years, when all the really needed parts are out of stock? Yelp thats why they have em no one needs them...
Old Nov 2, 2002 | 02:00 PM
Seven Is Coming
Cause they never come off .
~T.J.
Old Nov 2, 2002 | 03:53 PM
Rx7carl's Avatar
Airflow is my life
I agree, the marker lights look silly w/o the molding. Theres got to be a newer car in the junkyard with more streamlined lights.......hmmmmmmmm....
Old Nov 2, 2002 | 03:58 PM
Newbie
The way to remove rhese is heat...est to use a heat gun, if you have any friends that build Radio Controled air craft they may well have one. These guys use the gun to shrink the plastic film on the planes...Hair drier not really hot enough.ed
Old Nov 2, 2002 | 05:53 PM
Rx7carl's Avatar
Airflow is my life
But you gotta be careful, a heat gun can burn your paint right off too!
Old Nov 3, 2002 | 06:34 PM
suntzumd's Avatar
Ok, so how do I stick one of them back on?
Old Nov 3, 2002 | 06:58 PM
rgus30's Avatar
go to an auto paint place and look for the 2 sided tape its a 3m tape and very sticky , put it on warm .. like heat the area and the tape just a littleAND make sure its has a clean area to stick to... thats it
later
Th0m4s
Feb 26, 2019 02:04 AM
Professorpeanutrx7
Aug 18, 2015 03:09 PM
