Advice on driving a blown engine
Old Oct 19, 2002 | 04:09 PM
Snrub's Avatar
So I am going to be driving around in my daily driver, even though the engine is blown. (no smoke, at certain revs/throttle doesn't sound *that* bad) I'm waiting for an engine to be built for me.
1. Should I be doing anything differently?
2. Why does my A/F gauge read normally if not a bit lean? (millage isn't good, although better than I might have expected)
3. Is there any point in running 92 octane? While it needs a lot of throttle, it's obviously not running substantiall boost. What am I going to do, blow a apex seal?
4. Anything else?
Thanks.
Old Oct 19, 2002 | 04:31 PM
jmseven's Avatar
Asset is Wealth
I drove my first SA 40miles, running on the front rotor. Still drove...(rough)...but, I made it to my destination.
Old Oct 19, 2002 | 04:46 PM
Scott 89t2's Avatar
SOLD THE RX-7!
your biggest problem would be starting it...
if you can start it and drive it, it's proabbly not blown... just very worn and lacking in compression.
Old Oct 19, 2002 | 07:17 PM
hypntyz7's Avatar
No, some blown engines with all 3 apex's on one rotor will still start and drive just fine, other than being weak. Others, more commonly turbo II's, will barely start if at all. Just drive it like it is. IF you have the ability and time, find out which rotor is dead and remove the injector clips for that rotor, primary and secondary injectors so it wont be firing fuel into a dead rotor, should help your mileage a lot.
Old Oct 19, 2002 | 09:30 PM
Snrub's Avatar
So let's say only 1 seal on the front rotor is cracked, think it's work detaching the injectors for the front?
Old Oct 19, 2002 | 10:33 PM
hypntyz7's Avatar
No, if any face of the dead rotor is making compression then it's still firing, adn removing fuel from it means you'll lose a bit of starting adn driving power. 90% of blown engines lose an entire rotor though, make 0 compression in that half, and there isnt any use in dumping raw fuel into that chamber in that case. I have actually seen a couple of exhaust fires that started because of that, even though I personally have driven many a blown engine car with no problem, but if you can, unhooking that 2nd set of injectors will help depending on the compression.
Old Oct 20, 2002 | 01:58 AM
Rpeck's Avatar
What R U thinking self?
Re: Advice on driving a blown engine
My advice .... don't.
Old Oct 20, 2002 | 02:08 AM
hypntyz7's Avatar
WHy do you say that? Hell, if it's his only mode of transportation, and it still starts and runs decent, I say go for it. ****, Ive done it many a time. It's not like he's gonna do any more damage to it ya know...
Old Oct 20, 2002 | 02:18 AM
Rpeck's Avatar
I hear what your saying .. if you have to you have to. But I am a firm beliver of ... 'if its broke fix it'.
Old Oct 20, 2002 | 02:26 AM
hypntyz7's Avatar
Yeah, you're right. HE obviously shouldnt plan on driving this car as is until next year on his birthday when he might get a new car or something...
BUt, if he needs to go somewhere, and has no other way, hop in the old 7 and make it earn it's keep a while longer. Better than walking or not going...
Old Oct 20, 2002 | 02:37 AM
Rotorific's Avatar
I dont know a damn thing
Hmm i say drive on it if its not smoking i drove the **** out of my blown coolant seal but thats a totally different ball game
Old Oct 20, 2002 | 03:32 AM
fastrotaries's Avatar
W. TX chirpin Monkey
baby it, and only drive it if you have to......long trips are definitely out of the question.
Old Oct 20, 2002 | 09:59 AM
Snrub's Avatar
I am getting it fixed, however I can't just press a button and have a solution ready for me. So far it has had two 200km (trips ~130miles) @ 90kph (~57mph). It will have to do one more of those and my daily driving needs for up to a month. I don't see any reason it shouldn't be able to do that. Obviously the one rotor is under a lot of stress, but think about the total number of miles it would have gone if the other rotor hadn't died. Any other tips?
cdn
14
Sep 10, 2015 06:23 AM
fastrx7man
33
Sep 2, 2015 09:42 PM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
