Main Ecu Wiring harness?
Old Oct 19, 2002 | 02:04 PM
86Rx7GXL's Avatar
Is it ok to lengthen or shorten wires on the main ECU harness? Like wires going to the injectors, and everything else in that harness? I've heard you cant with the O2 sensor cause it goes by resistance. Is this true? Reason being I removed everything that I could and I just what to take different routs with the wires and most I need to shorten but dont know if I can.
Old Oct 20, 2002 | 11:46 PM
86Rx7GXL's Avatar
Anyone?
Old Oct 21, 2002 | 11:07 AM
86Rx7GXL's Avatar
someone should know
Old Oct 21, 2002 | 11:16 AM
Jimmy325i's Avatar
No longer cares
the change in resistance is so minimal for ANY of those wires that functionality will not be affected if you shorten them. I'd be weary of lenghthening them by any great distance (say putting ecu in back of hatch for whatever reason) because the current required to drive the injectors will increase as the voltage drops.
Old Oct 21, 2002 | 01:57 PM
Icemark's Avatar
I wouldn't be concerned with the change of the resistance for shortening the wires, other than your connections themselves as I am assuming you are not just shortening the wires into stock connectors/pin, but are instead butting the shortened wires together.
Old Oct 21, 2002 | 11:18 PM
86Rx7GXL's Avatar
alright sounds good. well what im thinking of is just gonig arcross the firewall and onto the engine instead of the factory way. i seen thes way done with a haltech setup.
Old Oct 25, 2002 | 05:36 PM
RETed's Avatar
Go for it...
The O2 sensor wire is shielded, and you have to be careful with the shielding - one loose strand and you'll end up with a short to ground.
-Ted
82streetracer
Aug 23, 2015 09:28 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
