Kaaz or Cusco LSD
Old Oct 19, 2002 | 11:51 AM
David88vert's Avatar
r71's daddy
Kaaz or Cusco LSD
Anyone know where I can find one for a GSL-SE? Price?
Old Oct 19, 2002 | 11:55 AM
Manntis's Avatar
add to cart
is there an advantage over the stock LSD in the SE?
Old Oct 19, 2002 | 12:11 PM
Rx7carl's Avatar
Airflow is my life
I believe those brands are Torsen type, so if they are then yes.
Old Oct 19, 2002 | 12:23 PM
Directfreak's Avatar
I am a Jeeper Now.
Re: Kaaz or Cusco LSD
I don't know if those fit an FB. Try the Gurumotorsports one from AUS.. It's real nice.
Old Oct 19, 2002 | 01:32 PM
RacerX7fb's Avatar
paradox
Get the Miata Torsen, those will fit 84 and 85 Rexes. The Torsen 2 cost less than the earlier Torsen 1.
the GSL-SE is actually missing a friction plate
Mazda musta left it out for the masses of mundane drivers who purchased the cars
Old Oct 19, 2002 | 08:55 PM
I am a Jeeper Now.
Can you go into more detail? Please explain, as this is the 1st time I hear anything like this.
Thanks.
Old Oct 19, 2002 | 09:57 PM
someone82's Avatar
Couldn't you just over-stuff the lsd with clutches and friction plates (am i correct?), like many mustang guys do?
When my dad had 3.55 gears installed in his cobra, he had the lsd over-stuffed and a rear end girdle installed. The rear-end hooks better then it did in stock form.
matt
Old Oct 19, 2002 | 11:53 PM
Attila the Fun's Avatar
I e-mailed Kaaz about a year and a half ago and asked what the had for a GSL-SE. The reply was "Nothing". I bought the Miata Torsen from Mazdacomp.
Old Oct 20, 2002 | 03:41 PM
Rx7carl's Avatar
Airflow is my life
Someone, you can add a clutch and plate, but you have to shave all the others down a little to get another one in there. Atilla, how much was the miata from Mazdacomp?
Old Oct 20, 2002 | 03:55 PM
Manntis's Avatar
add to cart
TorSens aren't LSDs. They don't slip before locking; they just transfer torque to the wheel with the most traction
Old Oct 20, 2002 | 04:06 PM
stinkfist's Avatar
Learn to swim.
I know a guy that has a KAAZ Diff with in his GSL-SE. I think he payed $1,200 for it. you can contact KAAZ here http://www.kaazusa.com/index.html
Mike
Old Oct 22, 2002 | 11:12 AM
1st7heaven's Avatar
One of the local autocrossers here talked to Kaaz and they had to have 10 guys commit to purchasing before they would build them.....$1200 ea.!!!! NO LUCK.
Go with either the Miata or the GURU...either way you are looking around $800.
DONT use the Torsen set up for drag racing, you will blow the thing apart!!!! Keep the LSD for dragging and Torsen for autocrossing or road racing.
Old Oct 22, 2002 | 11:43 AM
MikeLMR's Avatar
'Last Minute' Rallying
Thats why they are called torque biasing diffs
1st7heaven why would drag racing blow a torsen diff ? IF it were up to the power you were putting through it wouldn't it be OK ?? or am I missing somthing
I always thought LSD's were the weak ones ... being not as robust as open diffs or torsens ??
Old Oct 22, 2002 | 11:54 AM
1st7heaven's Avatar
I am not a drag guy so I can only go by what Ari at RX7.COM tells me. Apparently the torsen cant take the shock of the unloading of the clutch, they say it just cobbles up the spyder gears. The LSD gives the cusion needed to absorb the shock.????? Like I said, I am not a drag guy this is what the guys doing it told me. By the looks of what I saw this weekend, no one uses the torsen at the drag strip.
Old Oct 22, 2002 | 12:04 PM
MikeLMR's Avatar
I think most serious drag racers run a locked diff don't they ? that would provide the most traction I think ... I would have though thats why the guy in the other thread broke both axles ... would've broken one only if wasn't locked ??
like I said I'm probably missing somthing vital here
Old Oct 22, 2002 | 02:04 PM
1st7heaven's Avatar
I should have said.....the street classes run the LSDs.
We talked to another guy at the race that runs a Mits. all wheel drive, 800hp 4 cyl.
He broke his right rear shaft, after it let loose the back lash snapped the front left shaft and gobbled the transfer case in the front!!!
Depending on the HP and extreams, it will still break when the power is release from the side that breaks then transfers to the other. In lower hp cars, maybe a couple hundred hp I dont think you would see this......I dont know?
Old Oct 28, 2002 | 09:44 AM
I haven't been ignoring you. I was trying to find the receipt, so i could give you the precise figure. Since I haven't fount it, I'll have to rely on my admittedly fuzzy memory. I believe it was about $650.
Old Nov 2, 2002 | 11:33 PM
Found it! $640.55
Old Nov 3, 2002 | 12:16 AM
1st7heaven's Avatar
Ari at RX7.com can now get a Kaaz for something like $1200. He has them in stock!!!
Old Nov 12, 2002 | 11:30 AM
Silver93T's Avatar
Braap Braap Braap BOOM!
I destroyed my stock torsen during a moderate lanch from a light on street tires. Actually started easy in 1st, then punched it. Slammed it into 2nd and boom. They are just too weak in my opinion. The gears can't absorb the impact and strip. I'm probably going to go with a T2 visous differential. Supposedly it is alot stronger.
Old Nov 12, 2002 | 12:23 PM
jeremy's Avatar
male stripper
ok, mr technicality, lol.
Old Nov 12, 2002 | 01:11 PM
rx7gslse's Avatar
EX Pres of DFW Drunks
if you guys want info about what type LSD's came in what Mazda's (7 & miata) and what's interchangeable, here is a great link detailing the info.
http://members.aol.com/solomiata/MiataVLSD.html
Old Nov 12, 2002 | 01:31 PM
1st7heaven's Avatar
Not to change the subject.....did you sell your SE, GSLSE?
Old Nov 12, 2002 | 01:50 PM
rx7gslse's Avatar
not yet... still sitting @ my apartment complex.
Probably going to go up on ebay in the next week or so.
Old Nov 12, 2002 | 02:12 PM
Silver93T's Avatar
So the viscous isn't a performance unit? What about the t2 viscous? I might want to get the clutch type t2 unit then.
