Idiot light clock fix EASY
Old Oct 19, 2002 | 12:19 AM
Slammedblk7's Avatar
Yes its slow
im sure that majority of yall have probs with the clock
i found that if you just take it apart, the 4? points directly behind the clock, just need cleaning...grab a rag and rub off the points cleany and then hook it back up and it should light up...hey its worth a try, easy takes about 5 minutes....it worked for me...ERic
Old Oct 19, 2002 | 01:27 AM
ra ra rotory's Avatar
hmmm, ill give it a try, thanks
Old Oct 19, 2002 | 01:41 AM
Sean_O's Avatar
How do you pull off the cover around the clock, or is there an easier way?
Old Oct 19, 2002 | 01:44 AM
fastrotaries's Avatar
W. TX chirpin Monkey
dude make a how to!
Old Oct 19, 2002 | 09:15 AM
rootsgroup's Avatar
I'm too old for this *%*!
Fixed my clock awhile back, was going dim, or out, whatever it wanted to do. I performed the same disassembly as Eric, got to looking at those same solder joints with a magnifying glass, and found tiny cracks around the conductor. These are known as "cold" joints. They generally occur because of a poor solder procedure, and can be helped along over the years by vibration.
Anyhow, resoldering these joints with an iron suitable for circuit boards and reassembly did the trick.
Hope this is a help.
Rootsgroup
Th0m4s
Feb 26, 2019 02:04 AM
Microtech
30
Apr 23, 2016 06:37 PM
tsmith94FD
Aug 16, 2015 05:41 PM
