rattle when clutch in?
Old Oct 18, 2002 | 02:43 PM
jayk's Avatar
I've noticed a noise when I have my clutch depressed, it sounds like a loud metallic rattle that seems to be getting worse. It doesn't happen when in neutral and the clutch is out, or when in gear with the clutch out.
I'm guessing I'm going to need a new clutch soon, but does the rattle indicate anything else going bad?
Also, if I do need a new clutch, are there any worthwhile aftermarket options for a street driven car?
Old Oct 18, 2002 | 03:07 PM
rotary-tt's Avatar
2 babies - no back seats
The rattle is the throw out bearing for the clutch which is bad.
Old Oct 18, 2002 | 03:20 PM
jayk's Avatar
This might be a stupid question, but is there anyway of knowing how close it is to going completely bad? The car still drives fine, its just noisy. The reason is I'm about to transport it from california to maryland and would rather do the work there than try to find a place to put in a new clutch in the next week. It just needs to be "operable" so they can drive it on and off the truck.
Old Oct 18, 2002 | 03:32 PM
allrotor93's Avatar
the clutch may not be bad...maybe just the bearing.
Old Oct 18, 2002 | 03:37 PM
jayk's Avatar
Will a bad bearing make it catastrophically fail at some point in the near future? Or is it the kind of thing that will just be noisy until replaced?
Old Oct 18, 2002 | 03:40 PM
Tim Benton's Avatar
FD title holder since 94
is it the throwout bearing when the rattle is in neutral, but goes away when you press the clutch in?
Tim
Old Oct 18, 2002 | 03:48 PM
jayk's Avatar
Since I got the car > 2 years ago, I have had a much quieter rattle when in neutral and clutch out, although it goes away when the clutch is in. I always thought this was a normal noise, and have had mazda dealers (ivan at sunnyvale) tell me it was normal.
This new rattle is loud enough to scare people next to me in traffic and only happens with the clutch in.
Old Oct 18, 2002 | 05:32 PM
jspecracer7's Avatar
1JZ powered
It sounds like a throw out bearing to me.
Old Oct 18, 2002 | 09:19 PM
rotary-tt's Avatar
On and off the truck should be fine but I wouldn't drive it across the country.
Old Oct 19, 2002 | 01:54 AM
jayk's Avatar
I wanted to drive cross country but suspected I'd have to do alot of work to the car first... I guess I was right.
Old Oct 19, 2002 | 05:16 AM
Tim Benton's Avatar
so is it the throwout bearing for both situations? clutch out, neutral, makes noise (more than normal) but goes away with clutch in.....as well as makes noise when clutch in?
Tim
Old Oct 19, 2002 | 08:02 AM
David Hu$tlerhoff's Avatar
same problem overhere
when i step on the clutch-pedal the rattle goes away. i gets quiter when i drove it for a while though.
i only hear this in neutral
breakfast
Sep 20, 2015 07:06 PM
Rotospectre
Sep 13, 2015 11:22 PM
risingsunroof82
Sep 9, 2015 08:06 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
