atkins 3mm seals
Old Oct 17, 2002 | 11:22 AM
vanix's Avatar
atkins 3mm seals
Does anyone know what type of 3mm seals Atkins Rotary uses in motors they rebuild.
Old Oct 17, 2002 | 12:01 PM
hypntyz7's Avatar
I would say their own, since they make their own 2mm seals.
Old Oct 17, 2002 | 01:57 PM
vanix's Avatar
I'm trying to find out because I heard that the 3mm hurley seals are bad and I wanted to find out if thats what was put in my engine
Old Oct 17, 2002 | 02:03 PM
Where have you heard that Hurley seals are bad??
Old Oct 17, 2002 | 02:05 PM
fastrotaries's Avatar
W. TX chirpin Monkey
dude.....whoever told you that Hurley seals are bad was lying to you. They are some of the best on the market. For the dollar they are hard to beat.
Old Oct 17, 2002 | 02:25 PM
vanix's Avatar
I was told that KD used those 3mm seals in their motors untill the motors started going bad and now they don't use them any more. This scared me alittle because my car has a ported 13b with 3mm seals, from atkins and I don't know what type of seals they use.
Old Oct 17, 2002 | 02:33 PM
autocrash's Avatar
Now with more 1st Gen!
I would imagine that atkins rotary would use atkins seals...
....just like hypntyz 7 said....
...you could always call them...
Old Oct 17, 2002 | 02:40 PM
vanix's Avatar
If someone on here can't tell me for sure I will have to give them a call.
thanks
Old Oct 17, 2002 | 04:25 PM
hypntyz7's Avatar
I found on their website their own 3mm seals so Im sure they use those. At this point it doesnt really matter for you anyway, since you already have the engine, yes? BTW hurley seals are very good as well.
Old Oct 17, 2002 | 04:27 PM
knight1976's Avatar
And if it had hurley seals what would you do? Drive it till it died or would you run down and have them immediately swapped out with seals you trust?
Yea i think we all know the anwser to that question.
Not to mention that IF Hurley did suck then those seals would NOT be in a Atkins motor.
Old Oct 17, 2002 | 06:09 PM
Mr rx-7 tt's Avatar
rotary sensei
The stock 2 mm seals are the best.
Old Oct 18, 2002 | 12:31 PM
vanix's Avatar
You are right I wouldn't do anything about it I just wanted to know.
My friend when up to KDR and they told him that the hurley 3mm seals were no good. I beleive them since they have more experience than me and for that matter most of you when I comes to internals. But if by some chance one of you has more experience then can you give me proof that the hurley 3mm seals aren't bad.
Old Oct 18, 2002 | 12:52 PM
maxpesce's Avatar
Ex fd *****
The truth is the ONLY valid reason to use a 3mm seal is to to reuse an otherwise good rotor that the seal groves are worn too much to use 2mm seals - 2mm seals seal better and produce less friction drag than 3mm seals.
Atkins makes all there own apex seals - I Doubt the ever put any other apex seals in one of their motors unless specifically requested by the client.
Logan Reinisch
44
Sep 17, 2018 12:20 PM
