Lots of white smoke at start-up. Engine bad?
Old Oct 17, 2002 | 09:02 AM
Aico's Avatar
Me and my buddy were looking at a FC. He started it up while I watched the back. There was a lot of white smoke. A LOT. We drove it and the left silencer/exhaust was leaking. We couldn't get it over 3PSI.
Is the white smoke an indication of a bad engine?
Is the low boost a result of a bad exhaust?
Old Oct 17, 2002 | 09:12 AM
Rxmfn7's Avatar
Do a barrel roll!
Did you notice the coolant level?? White smoke is usually an indication of bad water seals = bad engine. The low boost also could be a result of this Id think, but Im not really a turbo guy so Im nor too sure.
Old Oct 17, 2002 | 09:28 AM
Aico's Avatar
If the coolant seals are bad, should there be white smoke the entire time or just at the startup?
Old Oct 17, 2002 | 09:42 AM
Josepi's Avatar
Despise Enmity
This can happen as well, it'll let the seal slip out of place and let coolant in.
But it does seem that your getting coolant seeping into the combustion area after you cut the car off (system is still pressurized).
Old Oct 17, 2002 | 09:43 AM
Josepi's Avatar
Despise Enmity
It may not be as noticeable if it is a small leak. But a small leak over a few hours may be enough to create the smoke that you see on startup.
Old Oct 17, 2002 | 11:27 AM
StarionX's Avatar
It's also going to depend on ambient temerature. If it's very cold, white smoke on startup is normal, but it should disappear after about 10 minutes or so.
cristoDathird
28
May 30, 2019 08:47 PM
elfking
Aug 19, 2015 09:48 PM
gtcd
30
Aug 19, 2015 02:44 AM
pzr2
Aug 15, 2015 08:29 PM
