Clutch Problems
Old Oct 15, 2002 | 11:57 PM
TwoRotorMotor's Avatar
Clutch Problems
Question #1:
Ok, my clutch grabs right away, but if i shift at high RPM's the clutch slips really bad, could there be air in the fluid lines? or is my clutch needing to be replaced?
Also, is my trans supposed to be really loud, or is that because of my clutch problem.
Question #2:
I need to rebuild my engine because it has a serious oil leak, would it be chaeper to upgrade to a new late 80' early 90's EFI engine? what should i expect to pay for the swap/engine/trans?
Question 3#:
I live in british Columbia, Canada, does anyone know of a good place to get my engine rebuilt/swaped?
Old Oct 16, 2002 | 11:10 AM
rebuild your engine yourself. It is fun!!!
Old Oct 16, 2002 | 05:00 PM
rx7passion's Avatar
have you tried adjusting the clutch? how many miles are on it? if its fairly old you have to adjust it all the way in one way.
depends how much horsepower you want and how much $ you have..
Old Oct 16, 2002 | 05:27 PM
82transam's Avatar
Never Follow
How do you adjust your clutch?
Old Oct 16, 2002 | 11:42 PM
Ok, thanks for the input.
Do you have a suggestions on a manual that is out for rebuilding the 12a's?
Old Oct 17, 2002 | 03:36 AM
680RWHP12A's Avatar
clutch height is adjusted by lengthening or shortening the rod that connects the clutch pedal th the clutch master cylander.... loosen the lock nut 12mm wrench and adjust it untill you like it!
Enzo1944
Sep 6, 2015 08:57 AM
vmerino
Sep 5, 2015 11:26 AM
