85 rx7
Old Oct 14, 2002 | 03:45 PM
mike zarkowski's Avatar
Newbie
85 rx7
I'm new at this so excuse me if I mess up.
my 12A engine won't fire up . This happened all of a sudden . I started to go through the usual tests. when I pulled #1 trailing plug to see if it had spark I noticed that it was soaking wet. At first I thought it was waterbut now I'm not sure cause the wet plug smells like gas. Next test, I drained the cooling system took out all the spark plugs , turned the engine over for 20 sec.to clear combust. chambers of excess moisture reinstalled plugs, tried to start eng. again , It would fire for a while but would not start engine seems to be flooding , what the heck is my next move?
M. Zeek
Old Oct 14, 2002 | 03:49 PM
82transam's Avatar
Never Follow
If it is flooded then you'll have to un-flood it. Which, from what i've read is different from un-flooding a boinger. i'm sure someone can supply the info on how to do that. Also, if you car is flooding then it might be running too rich.
Old Oct 14, 2002 | 04:04 PM
1rx7owner's Avatar
Lifes a garden dig it.
My car did that the other day, couldnt get it to start for the life of me. Didnt know why just wouldnt start. So I hooked it up to the back of my jeep and had had my wife pull me around until it did start. Didnt take that long figured I may have flooded it or soemthing. Starts up fine now though.
Old Oct 14, 2002 | 07:15 PM
Newbie
flooding
THANKS FOR THE INPUT, IV'E DONE SOME MORE INVESTIGATING, THERE IS WATER IN THE COMBUSTION CHAMBER FOR SURE. TIME FOR A BRAND NEW USED MOTOR I GUESS THANKS AGAIN MZ
Old Oct 14, 2002 | 07:19 PM
82transam's Avatar
Never Follow
well, you could always rebuild it. if the apex seals are still good, you can just replace the gaskets.
Th0m4s
Feb 26, 2019 02:04 AM
