New Motor,Apex seals not seated right causing flooding?
Old Oct 14, 2002 | 12:45 PM
Resource's Avatar
Car will start up fine in the morning but after I turn off the engine and try starting it again it's flooded on the rear rotor.I just replaced the apex seals on the rear rotor so I'm thinking I didn't get the apex seals seated right?
The compression is perfect so not sure what's causing this??
Thanks
Old Oct 14, 2002 | 01:16 PM
Jeff20B's Avatar
Lapping = Fapping
Apex seals don't give you gas.
Old Oct 14, 2002 | 02:51 PM
Resource's Avatar
I meant gas leaking between seals.......anyways nevermind it's fixed.
Old Oct 14, 2002 | 06:50 PM
Scalliwag's Avatar
WingmaN
What was wrong other than the seals needing time to seat?
Old Oct 14, 2002 | 08:36 PM
Resource's Avatar
I thought it kept getting flooded but it was trashed plugs.I changed the plug and everything is fine.....
Those mismatched hurley seals and mazda seals are doing great so far
Old Oct 14, 2002 | 09:38 PM
Scalliwag's Avatar
WingmaN
Plan on cleaning plugs pretty often during the break-in.
Old Oct 15, 2002 | 11:09 AM
jeff48's Avatar
Rotorally Challenged
Eric
Glad to hear you are up and running.
I should be rolling by next Tuesday.
Let me know when you want to get into the datalogit.
Jeff
Th0m4s
Feb 26, 2019 02:04 AM
sYnth.
Aug 19, 2015 06:27 PM
