Loseing oil question?
Old Oct 14, 2002 | 11:44 AM
Dragonz818's Avatar
I changed my oil about a month ago. It has about 2000 miles on it now. I check the oil once and awhile.
Last night I was driving and my oil light went on and off. I was like a **** and turned around and went home.
I looked it up on the forum last nigt and found that our oil senders go bad pretty easily. I thought that may be the problem but my car only has 15,000 original miles.
This morning I checked it and it was like half a quart or more low.
Is this something to worry about?? I know we burn oil but is that alot? Ihavent checked it in a while so I could have slowly been losing it. Never ever see oil laying on the ground and I always check for that.
Is thier something to look for to see if their is a problem.
I am running Castrol GTX I think 5w 30. What ever the manual says. Thanks
Jerry
Old Oct 14, 2002 | 11:45 AM
Dragonz818's Avatar
That light doesnt indicate oil pressure right, only oil level??
Old Oct 14, 2002 | 12:31 PM
maxpesce's Avatar
Ex fd *****
Yes the LIGHT is for oil LEVEL as far as I know the LEVEL sensor is very reliable BUT the PRESSURE sender is quite prone to failure.
The Oil Metering pump (OMP) sould inject oil (from the sump) into the rotor chambers at the rate of 1qt in 750<>1000mi depending on how hard you drive. The turbo oil seals are also prone to failure and can significantly increase oil consumption - Check inside your intercooler piping for excess oil - a light coating is OK, a Puddle in the bottom of the Intercooler indicates Bad seals on the Compressor side of the turbos. another indicator of a leaky secondary turbo is oil in the Charge Relief Valve discharge hose leaking into the AIRBOX
My Turbos currently leak enough to increase my oil consumption to 1qt/350mi.
Old Oct 14, 2002 | 12:38 PM
Dragonz818's Avatar
Will do thanks
Old Oct 14, 2002 | 12:43 PM
blackscorpio's Avatar
#1 F0RUM TROLL
I would never go 500 miles without ceckin the oil much less 2000, I would just add more oil and pay more attention to it from now on. At the very least a FD will burn a quart between oil changes.
Old Oct 14, 2002 | 01:21 PM
Dragonz818's Avatar
Thats pretty much what I did only checked it once between oil change and I am was about 3/4 quarts low.
I got in the habbit at checking coolant levels but slipped with oil.
Thanks again
Old Oct 14, 2002 | 03:37 PM
Dragonz818's Avatar
bump
Old Oct 14, 2002 | 03:54 PM
RX7Elmo's Avatar
i don't see why you need to bump the thread since your questions have been answered.
the OMP will burn oil. I say 1 quart per oil change is about right. it depends on your sort of driving. Also, i wouldn't use 5W-30 That is too thin. You have to use at least 10W-30. I use 20W-50
Danny
Old Oct 14, 2002 | 05:23 PM
Dragonz818's Avatar
I know what you posted but I know that my car didnt burn 1 quart of oil before my last oil change so I am hopeing someone esle would post that maybe can bring up a different point
Old Oct 14, 2002 | 05:25 PM
Dragonz818's Avatar
I know that their must be many reasons and I dont believe my car is just all of a sudden sucking oil.
Old Oct 14, 2002 | 05:27 PM
maxpesce's Avatar
Ex fd *****
Don't forgett that the diff between the LOW and FULL marks on the dipstick = approx1.6 quarts (1.5L) not 1qt as on most US cars
Frisky Arab
13
Aug 18, 2015 05:30 PM
