Still Idleing at 2200
Old Oct 12, 2002 | 08:24 PM
95R2-89TII Ground Zero's Avatar
Banned
Okay, after a week of working on my 7 I still have no idea what the hell is going on. It still idels at 2200 and won't idle down. I check all of the vaccuum lines and I can't see any split or off. I started the car and let it idle for a minute, then I unplugged the MAP sensor and the car idle out and quit running. I also checked all of the connections on the idle control and those seem to check out. What else can I look at, I'm running out of ideas. I also reset the ECU and that didn't work either. Any help is appreciated. Thanks
Old Oct 12, 2002 | 08:31 PM
Fd3BOOST's Avatar
Recovering Milkaholic
Did the throttle position sensor get moved at all from it's original placement?
Old Oct 12, 2002 | 08:45 PM
jacobcartmill's Avatar
just dont care.
turn the idle stop screw.
Old Oct 12, 2002 | 08:49 PM
Fd3BOOST's Avatar
I was hoping he tried the idle adjustment screw already. But yes if he has not then that would be the first thing to do.
Old Oct 12, 2002 | 09:33 PM
just dont care.
Old Oct 12, 2002 | 09:41 PM
paw140's Avatar
My car idled at 2000+ rpm and I could not adjust it at all. It turned out my lower intake gasket was blown. I'll describe one thing I tried, although I don't necessarily recommend this, but it will eliminate leaking gaskets.
I removed the hose that goes from the IC to the intake elbow. I then started the car. I placed my hand over the intake elbow opening, competely covering it up. You will feel the engine vacuum trying to suck your hand in, but it should be ok. When I did this with a blown lower intake gasket, my idle speed still did change. All of the air that goes into the engine *should* go through the elbow, so I was effectively cutting off all the air, and the engine should have stalled. The fact that nothing even happened to the idle clued me in that I had a MAJOR leak somewhere. If you don't have any vacuum leaks, your engine will stall if you cover up the intake opening.
Just a thought, if you have nothing else to try.
Old Oct 12, 2002 | 09:43 PM
paw140's Avatar
I just read this again. Definitely check the idle stop screw first and try adjusting that. If that fails, you may want to try my procedure.
Old Oct 12, 2002 | 10:01 PM
rpm_pwr's Avatar
What manifold vacuum do you get?
Here's two quick test b4 you go ripping off the UIM.
1) Throw the car in 3rd on the road and slow down til you get to 1000rpm. What vacuum do you see? If it's anything less (closer to zero gauge pressure) than 20" you have a vacuum leak. However a faulty idle air solenoid IS a vacuum leak in itself.
2) Pull of the electrical connector for the idle control solenoid. This closes it. Does the idle drop? If so there's your problem.
In my experience, the idle control screw doesnt just go out one day. More likely is something jamming the accel cable/ return springs and stopping it from properly closing.
HTH,
-pete
Old Oct 13, 2002 | 02:34 PM
Banned
I checked the thorttle linkage today, and it seems to be returning to place at idle...so it isn't out of wack. I'll check the others that were suggested later today and report back tonight.
Old Oct 13, 2002 | 06:17 PM
Silver93T's Avatar
Braap Braap Braap BOOM!
I had a 3k rpm idle a couple weeks ago. This happened after i had the upper intake plenum off to remove the double throttle butterflies. It turned out that the cruise control cable was binding and preventing the throttle from closing. I simply disconnected it. I plan to remove the cruise control soon anyway.
Old Oct 13, 2002 | 07:11 PM
Banned
I don't have cruise as its an R2. I did the 1000 rpm in third gear and the vaccuum on the boost gauge read 12. I take it that's good. So I don't have a leak anywhere. Any other ideas?
Old Oct 13, 2002 | 07:22 PM
paw140's Avatar
He said that anything under 20" would be a leak. If you have 12", something is wrong. You probably have a leak somewhere.
Old Oct 14, 2002 | 12:00 PM
Banned
Where could I have a damn leak at. There are a million lines under the intake. I already checked those ones under there....and I couldn't see anything out of the ordinary other than a couple of metal lines that don't have vaccuum lines on them at all. Any other ideas of what I should look at?
Old Oct 14, 2002 | 12:28 PM
blackscorpio's Avatar
#1 F0RUM TROLL
have you checked to make sure that the cruise controll cable isnt holding the throttle open. Mine got stuck that way one and took forever to figure out that the cruise controll cable had james slightly open.
Old Oct 14, 2002 | 12:31 PM
paw140's Avatar
I have never tried this myself, but others have suggested it. Spray carb cleaner or brake cleaner or some other flammable sovlent around your gasket areas (lower intake to block, UIM to LIM, throttle body, etc.) I guess if you spray on a vacuum leak, the engine will suck in the solvent and your idle will change. I always thought this was a dangerous approach, since you'd be spraying very flammable solvent on an engine, but others have used it sucessfully. Have you ever tried unplugging you idle air control motor (valve)? That might cause a problem too.
Old Oct 14, 2002 | 12:54 PM
Juancm5483's Avatar
question
WHAT IS IDLE ANYWAYS, 800? BECAUSE MINE IDLES AT 1,500 AFTER ABOUT 30 MINS OF DRIVING IT COMES TO 1,000... WHAT CAN THIS BE?
AND ITS NOT THE CRUISE CONTROL BECAUSE I JUST CHECKED IT AND ITS FINE...
Old Oct 14, 2002 | 01:40 PM
Banned
Okay....I don't have cruise control........it's and R2.
Old Oct 14, 2002 | 02:10 PM
mjw's Avatar
mjw
It sounds to me like you may have an intake leak like others are suggesting.. I would check on the hot wax rod/fast idle cam and make sure that thing is working. Did you reroute the coolant line or do you still have coolant flowing through the TB?
Matt
Old Oct 14, 2002 | 02:15 PM
Street King's Avatar
*** Bless Texas!
Do this and make sure your engine is cold and have a fire extinguisher ready. If at anytime the idle raises all of a sudden, there's your leak. PLEASE get a fire extinguisher. I didn't have to use mine but better safe than sorry. But the norm for a high idle is a vacuum leak.
Old Oct 14, 2002 | 03:03 PM
RotorMotorRX7's Avatar
Re: question
Mazda claims your idle should be 750. but ofcourse it differs with different cars. mine idles around 900
Old Oct 14, 2002 | 03:09 PM
*** Bless Texas!
Mine is 800 rpm's
Old Oct 14, 2002 | 03:11 PM
Banned
Matt
Where is that thing located. I have the Mazda Dealership manual, but if I don't have to look into it to find it....it would save a ton of time....thanks.
Old Oct 14, 2002 | 04:54 PM
rpm_pwr's Avatar
OK I just tested mine for you on the way to work today,
At 1000rpm in 3rd I'm pulling 18" and my motor is not ported. So if you're not ported, then you're way off. Pull the electrical connector off the idle solenoid. It's connected to the throttle body, with the connector facing the firewall. Tell me what that does. 2200rpm is a wide open IAC valve.
Also check the fast idle.
-pete
Old Oct 14, 2002 | 05:01 PM
mjw's Avatar
mjw
The fast idle cam is located on the firewall side of the throttle body, it is really hard to see or inspect with the TB on the car. If you remove the TB you will see it easily.
Matt
Old Oct 15, 2002 | 12:05 PM
Banned
Matt
I'll check that and the IAC tommorrow and let you know what happens. Thanks
