Power FC PowerFC Maps?
Old Oct 12, 2002 | 10:35 AM
reza's Avatar
PowerFC Maps?
Will there be more PowerFC maps posted on the PowerFC Maps section?
I think it was last updated like july 2001.
Or is there any good website/forum with PowerFC maps posted? I would like to get try different maps...
Old Oct 18, 2002 | 08:09 PM
Jodeny's Avatar
Indifferent
Don't change maps unless you have a datalogit or you have a very strong understanding of the PFC. I would hate to see someone blow their motor. THe commander does not allow you to change the base fuel map.
John
Old Oct 19, 2002 | 06:23 PM
DavidDeco's Avatar
I have more fun than you.
I would get a map that has your mods or close or else stay base until you can do some accurate A/F tuning.
Old Oct 27, 2002 | 11:57 AM
reza's Avatar
I just got a PowerFC. It is used. It has a different map for a car that has totally different mods than mine. That is why I asked the question above.
Are the base map good in the instruction+maps section?
I have the following mods now with stock ECU. I am waiting for my wideband install before going to PowerFC.
Mods:
- k&n drop in filter
- bnr stage1 turbo with ported wastegate
- downpipe
- high-flow cat
- N1 Duals with both silencer on(to limit flow)
- HomeDepot wastegate and precontrol valves (tuned to 10-7-10, I think the ported wastegate made is lower boost).
Any help/insight is appreciated.
Reza
Old Oct 27, 2002 | 03:46 PM
Badog's Avatar
Get a Datalogit. It should interface in with your wideband (whose is it?) an allow you to throw maps onto your car, datalog, and access portions of the PFC programming that you normally would not.
Get it, you won't be sorry. Edit: plus there are alot more maps on the Datalogit yahoo groups in DAT format (for the Datalogit, of course) that you'll be able to look at.
Old Oct 29, 2002 | 10:07 AM
jamesbahk's Avatar
hey badog you seem to be very knowledgeable can i ask you something about the pfc if i initialize the settings will it clear all data or will it reset to what it was originaly programmed to? oh by the way imppresive 1/4 times
Old Nov 10, 2002 | 04:11 PM
coop's Avatar
So if the map is based on the same mods, is it ok to start with that?
Old Nov 11, 2002 | 09:39 AM
evot23's Avatar
Classy
Yes, but again BE CAREFUL and study the map. Until you dyno with wideband you will not know for sure how that map fits your car.
2 cars witht he exact same mods can have some different settings....remember every engine is unique in some way and so will the maps.
Other maps are guidelines only to get you going.
Old Nov 11, 2002 | 09:43 AM
coop's Avatar
ok, thanks...I should head to the closest dyno and get an idea of where I am starting...
Old Nov 14, 2002 | 08:57 AM
ttpowerd's Avatar
HARRRRRRRRR
What is the site for the datalogit? Where do you sign up?
Thanks for the help!
Old Nov 14, 2002 | 09:25 AM
jr's Avatar
jr
http://groups.yahoo.com/group/Datalogit-FD3S/ but you need to be a member to access it and membership is by invitation only. If you own a Datalogit there should have been instructions on who to email to get invited.
Old Nov 14, 2002 | 09:47 AM
coop's Avatar
how long does it take to get invited? I sent in my info yesterday...
Old Nov 14, 2002 | 10:14 AM
jr's Avatar
jr
You'll probably here back from them late tonight, don't forget they're like 12 hours behind us over in Oz.
Old Nov 14, 2002 | 10:19 AM
Jodeny's Avatar
Indifferent
Do you have a datalogit?? If not you prob won't be invited
J
Old Nov 14, 2002 | 10:33 AM
coop's Avatar
I have it (just got it yesterday), I just sent the email with numbers yesterday as well.
Old Nov 14, 2002 | 10:37 AM
Jodeny's Avatar
Indifferent
should be soon then...
J
sukimoto
Rotary Car Performance
Oct 26, 2015 02:37 PM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
