engine idle
Old Oct 11, 2002 | 10:03 PM
xman's Avatar
Unhappy engine idle
I own an 82 RX-7, and I seem to be having problems with my engine's idle during warm-up. I only seem to have this problem during cooler weather. The car starts well, then just before complete warm-up the car will die unless I give it gas. If it dies and I re-start her she usually runs just fine. All of my emission's equip. has been removed (rat's nest, acv, air pump, etc), and aside from the idle thing everything runs fairly well. I've tried adjusting my idle and mixture and I was wondering if there's any other angle I can look into. Any help would be much appreciated!
Old Oct 11, 2002 | 10:23 PM
Rx7carl's Avatar
Airflow is my life
Is this before the choke drops off? or after? And how did you adjust the mixture?
Old Oct 12, 2002 | 02:29 AM
xman's Avatar
engine idle
It's before the choke drops off. Actually I forgot to mention that my emission control unit fuse (located under dash by the hood release lever) keeps blowing causing my choke **** to stop working. There must be a short somewhere, but I HATE electrical stuff, and have no clue where to look for a short, etc. I just keep replacing the fuse. Anyway, as far as the mixture, I just ran the engine until warm. At idle, turned mixture screw clockwise until the engine stumbled, then turned back counter-clockwise in small incriments until the engine ran well. Actually, it's running a bit rich I think, but I'm running with DLIDFIS and I heard that it's better to run a little richer. I don't think it's too rich, though I don't have an gas analyzer, and I don't have any emissions stuff anyway. My plugs don't look too carbon'ed either.
Old Oct 12, 2002 | 08:43 AM
Rx7carl's Avatar
Airflow is my life
Hook up a vacuum gauge to a manifold source and lean the idle mixture for maximum vacuum.
Old Oct 13, 2002 | 12:03 PM
xman's Avatar
Not 100% sure how the idle thing works. If I lean the mixture for maximum vacuume will that affect normal idle? (My vehicle's a daily driver)
Old Oct 13, 2002 | 01:13 PM
Rx7carl's Avatar
Airflow is my life
You do this adjustment at normal idle
Old Oct 13, 2002 | 02:44 PM
diabolical1's Avatar
xman~
where do you have your idle speed set?
Old Oct 13, 2002 | 09:20 PM
xman's Avatar
Initially had it too high between 950-1000, but reduced it to around 800.
Old Oct 13, 2002 | 10:05 PM
did it do the same thing when you had it at the higher idle?
Old Oct 13, 2002 | 10:17 PM
Rx7carl's Avatar
Airflow is my life
You balance it. Lean it till its at max vacuum. Then lower the idle speed, then lean it again....etc....etc...
Old Oct 14, 2002 | 03:32 PM
xman's Avatar
In regards to your question Diabolical1, yeah, it did the same thing when my idle was set high.
Rx7Carl, I will be picking up a vacuume guage (my old one is unreliable), and trying the mixture adjust again. Not to sound stupid or anything, but I'm assuming this is all done when the engine is at normal operating temp?
Old Oct 18, 2002 | 07:57 PM
xman's Avatar
Managed to get a vacuume guage and adjust my mixture/idle (thanks Rx7Carl). The engine idles much better now, but still has a tendancy to stall occassionally when warming up.
My idle (with engine warm) without any accessories/lights on is around the 750-800 range, but with accessories/braking or lights on, it tends to drop to around 400. Is this the result of the voltage drain, or the result of a drop in fuel pressure, or something else? Could my fuel pump be part of the problem? I haven't replaced the fuel pump, and it's looking pretty weathered. I'm at a loss as to what to check in order to correct the problem and any help would be MUCH appreciated.
(I'm kind'a leaning toward the electrical thing as I know I have some electrical problems).
Kyo
Apr 13, 2019 09:24 AM
alphawolff
Nov 17, 2015 05:57 PM
Tannergsl-setarga7
Aug 18, 2015 03:11 PM
ncds_fc
Aug 15, 2015 10:06 AM
