Tell me my engine is cooked.
Old Oct 11, 2002 | 07:47 PM
Please guys it's sad to hear but just tell me that my engine is done so I can put new engine and have real fun with my 7.
symtoms are.
5psi of pressure loss during 24 hours.
bubbles in the filler neck big and samlls all kinda of bubbles.
once in a while coolent light comes on.
When light comes on stock gauge hit H mark.
but aftermarket gauge shows no thing.
water running sound at the dash when start up.
water boilling sound after shut off.
coolant over flows some times.
Ok but I don't have problem with starting or white smoke.
all the hoses are new.
so post your opnion please so I can make up my mind..
thanks
Old Oct 11, 2002 | 08:01 PM
Street King's Avatar
*** Bless Texas!
That might just be a coolant problem...
Old Oct 11, 2002 | 11:16 PM
pomanferrari's Avatar
Check your hoses, caps, AST and radiator before you settle on the dreaded o-ring failure.
If no other causes, it's time for you to do a blockweld or to get another engine. My engine started with the same symptoms and then the add coolant light on every time.
I block welded it 3 times and now it's running great. No more add coolant light. Going on 6 months and 2500 miles since the block welds.
Old Oct 11, 2002 | 11:23 PM
ijneb's Avatar
FOR SALE
your engins done, get a new one, rebuild, streetport, go single, have fun!
"Please guys it's sad to hear but just tell me that my engine is done so I can put new engine and have real fun with my 7."
Old Oct 12, 2002 | 12:00 AM
seems like your engine is okay. no white sweet smelling smoke, most likely, means that your coolant seal is okay. I'd probably say you need to burp your system, check all your hoses and see if there are any leaks. Taking the upper intake manfold off might be a pain but it might be just one little hose that is causing the lost of psi.
As far as the difference in the reading your aftermarket termp. guage, check to see all your wire connections.
Nathan
Old Oct 12, 2002 | 01:18 AM
skunks's Avatar
I'm a CF and poop smith
check all the gaskets and hoses, i doubt your engine is at fault here, you probally just have a coolant leak like the rest of us.
Old Oct 12, 2002 | 01:28 AM
Thanks guys.
But I really want the truth because I can hadle the truth.
I could never push my car hard because of this issue.
I really want the car that I can push hard to hell when I want that's all.
thanks.
Microtech
30
Apr 23, 2016 06:37 PM
Wicked93gs
Aug 23, 2015 10:14 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
