will bad trailing ign cause no-start?- leading ign OK
Old Oct 11, 2002 | 08:17 AM
fmj355's Avatar
Sorry if this is a real bonehead newbie question, but I have leading spark and I have fuel , but no trailing spark - igniter problem I expect, but I would have thought it would start at least on just the leading spark.
Don
Old Oct 11, 2002 | 08:30 AM
RotorMotorDriver's Avatar
Seven Is Coming
In theroy, as far as I know, it should start on just the leading spark. Although, if its not starting, I would investigate the no trailing spark more just in case. Or maybe you actually have them backwards. Leadings are the bottom plugs, just so you know .
~T.J.
Old Oct 11, 2002 | 10:15 AM
metalliman's Avatar
I too was having problems with my trailing plugs. The connections on the ignitor were corroded. Nonetheless, it started fine with just the leading plugs, however sometimes it took a few turns to get it started. In fact, I drove it for a couple of weeks with just the leading plugs, however the trailing plugs were fouled out by the time I figured out it was the igniter.
Old Oct 11, 2002 | 04:48 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Yelp it will still run, on later models if the trailing doesnt fire, no tach
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
SakeBomb Garage
Vendor Classifieds
Sep 4, 2015 05:19 PM
