Need Help With Idle Problems
Old Oct 9, 2002 | 09:06 PM
I searched...but nothing described my situation. The last two times I have driven my car to my job, when I was letting the turbos cool my car started idling(?) funny. It was fairly smooth, but every couple seconds (5 or so) there was a kinda puff sound from my exhaust...like a sputtering...and the whole car would jerk. No smoke. What's weird is that I've only noticed it twice driving to the same place...nowhere else. Or maybe I'm just oblivious. Any ideas what would do this?
Thanks
Old Oct 11, 2002 | 09:09 PM
Unhappy
Anybody???
Old Nov 29, 2004 | 11:06 PM
jeremyb's Avatar
Hi....
I'm bringing this back from the dead.... i don't know why no one gave input on it...
TTT!
Old Nov 30, 2004 | 11:41 AM
jd to rescue's Avatar
jeremyb, are you having a similar problem? Is that why you are ressurrecting this thread?
Three possibilities come to mind: (1) you have a minor air leak in you intake; (2) you have an air leak in your air pump; or (3) you have a borderline grounding problem.
Old Dec 1, 2004 | 08:09 PM
jeremyb's Avatar
Hi....
(1) i checked my intakes no leak.
(2)My air pump DID have a leak... it was that rubber hose connecting the airpump outlet to the hardpipe next to the UIM. But i disconnected the connector to the air pump and blocked off the pipe that is supposed to connect to the air pump... yes it had lumpy idle... like it was humping the ground. So i guess that's the problem.
(3)i checked all the ground connections i can see they look find to me... but maybe a little fine steel wool would help?
**i brougt back this thread because i didnt know i had an airpump leak. Then a few hours after bumping this thread i found it. I'm gonna try put a new hose on it and hopefully itll solve my problem**
Thx JD
Jeremy
Old Dec 1, 2004 | 08:17 PM
RX7Wishing's Avatar
BOOOYAHHHH!
hrmm...
I had a similiar prob and it was fixed by adjusting my idle and changing a failing o2 sensor
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
ZacMan
Sep 19, 2015 09:20 PM
firzen
Sep 15, 2015 12:04 PM
rx7shirley
Sep 2, 2015 02:11 PM
