Symptoms of a shotty fuel pump?
Old Oct 9, 2002 | 07:42 AM
djmickyg's Avatar
Question Symptoms of a shotty fuel pump?
what are some of the problems i would have if my fuel pump was on its way out???
i got some problems which i thought were electrical but that all seems fine now.. and it shoulds like my engine isnt getting enuf fuel.
Old Oct 9, 2002 | 07:56 AM
DONNA's Avatar
have you checked the fuel output, pull off the large inlet hose from carb put the end in a container to catch/measure output (one nearest firewall) crank engine for few seconds, also could just be your fuel filter, they clog up at times,,,,mine did,,,,good luck
some info http://www.mazspeed.com/maz-cgi/mazbbs01.cgi
Old Oct 9, 2002 | 08:00 AM
djmickyg's Avatar
the fuel filter is only about 2 months old and is clean..
is there a measurment for the output flow rate?? like lt/min?
Old Oct 9, 2002 | 05:32 PM
ScruffyChimp's Avatar
It sounds like your pump could be going out the same way as mine.
One day I got in the car, put the key in the ignition, but they was no clicking sound from the rear (the fuel pump wasn't working). I thought the problem was the pump's plug under the rear seat, because when I cut that plug out and soldered the wires together it started going again.
But it was only a short term fix. Bascially, the pump would work fine one day, and then not go the next. I thought it was a wiring problem, but the pump was just stuffed. I replaced it and have no probs now.
Bye,
ScruffyChimp
Rotospectre
Mar 28, 2018 03:33 PM
ChrisRX8PR
Oct 18, 2015 04:01 PM
86glxNA
Aug 22, 2015 08:54 PM
