Help!!!
Old Oct 8, 2002 | 11:25 PM
cohbra's Avatar
Red face Help!!!
The other day I reconnected my airpump to the cat-convertor to try to pass emissions, and everything seemed to be fine. The car continued to run as normal, however, I shut it off, took it down off of the jack stands, fired it back up, and now it is running like crap. It seems like it is running really rich. I actually have a mist of fuel vapors coming out of the exhaust after shutting it off.
Initially it was idling really rough around 1500 rpm but it settled down and began to react somewhat normal again. Except for the smoking.
I began to trace down vacuum lines, and found nothing over the last day. Then, all of the sudden, I started it up again, and the smoking was gone, the idle was smoothe, and I thought the problem was gone.
Wrong I was!
Took it for a quick test drive around the block and it is backfiring like crazy when I let up off of the throttle. It also stumbles around 3-4000 RPM. (Similar to a fuel cut)
The car has the following installed:
-Power FC w/commander
-PF intercooler
-Pettit intake W/ K&N's
-Downpipe
-Highflow Cat
-Cat back exh.
I also just installed new plugs and cleaned my K&N airfilters. I only run high octane gas, and currently I have some octane booster in the tank as well. I am at a complete loss at this point and I am trying to remain positive that it is something simple.
Please help if you have had similar symptoms or any ideas I haven't tried yet.
Thanks in advance.
Old Oct 9, 2002 | 12:04 AM
Snook's Avatar
Tony Stewart Killer.
wont not having the air pump connected mess up the main cat or a high flow cat?
sorry this is all I know
Old Oct 9, 2002 | 12:07 AM
c00lduke's Avatar
have you tried resetting the ECU yet?
Old Oct 9, 2002 | 12:26 AM
wonder1and's Avatar
I Sold My Car 2 the Devil
Hey I ran into something similar w/ my car... run around in your PFC screens untill you see somthing named option 5 in there and see if it is selected or not if so deselect it and hopfully that will do it... you PFC probably did some CrAzY learning mode ****.... ps if your car is tuned don't reset the ***** or you'll be there for about 2 hours re-inputting the maps if you have them on paper... Hope this helps you can also pm me if you have more q's
Ryker
Old Oct 9, 2002 | 12:34 AM
cohbra's Avatar
Let me go check on the option 5 thing.
Old Oct 9, 2002 | 12:40 AM
cohbra's Avatar
The only thing that I see that mentions the word "option" is for the PIM Voltage settings. It has 5 choices:
normal
option1
option2
option3
option4
Is this what you are talking about?
Old Oct 9, 2002 | 12:44 AM
cohbra's Avatar
They all seem to have the same setting in each one also. 100%. Is there more to it than what I can see?
Old Oct 9, 2002 | 02:04 AM
cohbra's Avatar
does anyone know much about the power fc?
Old Oct 9, 2002 | 02:22 AM
cohbra's Avatar
Well, anyone else that has a Power FC, and may have this problem, it was the option that was selected that gave me the problem.
When I was browsing through the settings, I didn't realize that the option that is highlighted, when you hit the previous button to back out of the PIM Voltage settings, would be the one that would take effect. I changed it back to normal and now my car runs great!!
Thanks wonder1and.
you saved me a lot of money, I was about to take it to the shop at $80 an hour.
Old Oct 10, 2002 | 03:50 PM
wonder1and's Avatar
Glad I could help. Good luck w/ the PFC!
Ryker
[Dallas]
