Various bushings?
Old Oct 8, 2002 | 08:36 PM
slipperyslater1's Avatar
Various bushings?
Is their anyone out there that sells bushings in anything other than full kits? All I want is trailing arm bushings or diff. mounts?
Old Oct 9, 2002 | 03:22 AM
maxcooper's Avatar
WWFSMD
For the trailing links, you can get new links from M2 and other vendors that replace the rubber bushing at the leading (body) end with a rod end. You cen get toe links with a similar design, which also help reduce wheel hop.
I have some Unobtanium diff bushings that I would be willing to sell. I installed all the suspension bushings but never installed the diff bushings. I don't have any wheel hop now, and I figure I might as well keep the stock bushings to keep the noise and vibrations down. I dyed the bushings red, but I don't think the color matters much even if you don't want red, because they are tucked up under the car so you won't see them anyway. If you are interested in them, I will sell them for $90 including shipping in the U.S.
-Max
Old Oct 13, 2002 | 01:09 AM
gnx7's Avatar
www.suspension.com
-GNX7
pfsantos
Sep 30, 2015 01:29 PM
