To all the x-perts
Old Oct 7, 2002 | 05:58 PM
cohbra's Avatar
To all the x-perts
Is the airpump necessary for anything other than the cat-convertor? If I disconnect the line off of the back side of the engine, (Long enough to go to emissions and back), will it run ok?
Old Oct 7, 2002 | 08:01 PM
rynberg's Avatar
https://www.rx7club.com/forum/search...der=descending
Old Oct 7, 2002 | 08:03 PM
cohbra's Avatar
thanks
Old Oct 7, 2002 | 08:04 PM
Mahjik's Avatar
Mr. Links
If you are running a cat and disconnect the air pump from it, you'll start clogging your cat pretty quick (which will lead to not too favorable boost).
Don't disconnect the air pump UNLESS you are running a midpipe.
