AVCR speed signal
Old Oct 6, 2002 | 07:38 PM
ORX705's Avatar
Cheese
AVCR speed signal
I’ve hooked the AVCR speed wire up to the recommended speed signal off the cruise control and it constantly fluctuates +/- 20km/h of the correct speed. This is on a 89 rx7. Did anyone else have this problem with the AVCR? How do I fix it?
cheers
B
Old Oct 6, 2002 | 10:03 PM
AggieDave's Avatar
i didnt hook mine up at all
dave
Old Oct 7, 2002 | 12:28 AM
87GTR's Avatar
mine is connected and its rock solid but its on 87 T2.
Old Oct 7, 2002 | 02:35 PM
DaleClark's Avatar
RX-7 Bad Ass
Yeah, I have the exact same problem on my '88 Turbo with it hooked up to the cruise control output per Apexi's manual. That's WAY down on the list of things to do to the car - putting it back in one piece comes first .
I imagine it may be a flaky ground or something simple.
Dale
Old May 3, 2003 | 02:07 AM
Cheers!'s Avatar
Former Rx7 *****
back from the dead... question on the wiring hook up.
the purple wire of the AVCR acording to the manual is both for injector signal and speed signal.
The manual indicates location of stock wiring for both injector and speed signal.
which wire do i tap the purple wire into? speed or injecotr?
Old May 3, 2003 | 02:40 AM
astrochild7's Avatar
controlled kaos
i put it on the secondary inj. signal since my safc grabs my rpm signal. i don't seem to have any prob's with the speen signal from the cruise. i guess since it's fluctuating , just tighten and clean your cruise control...
Old May 3, 2003 | 11:51 AM
chatch's Avatar
How is the AVC-R. I've been looking at controllers and havent heard anything from an un-biased source as to how well it works. Whats the deal, is this thing worth the money?
Old May 12, 2003 | 10:52 AM
Cheers!'s Avatar
Former Rx7 *****
another back from teh dead post.
After installing the avcr i must say... wow... that thing is mint.
However i suffer the same thing...my speed fluctuates
Old Jan 19, 2004 | 08:00 PM
ORX705's Avatar
Cheese
i added an extra earth to my cruise control unit and it didn't help.
i can't get the self learn to work and i can only put it down to no speed signal.
Old Jan 19, 2004 | 08:06 PM
Madrx7racer's Avatar
same problem with mine, speed fluctuates, i thought it might be cuz of the bigger rims, but i dunno how to fix it, I have to when I intall my motor into the GTUs.....also I have mine in the "OFF" setting due to boost creep up to 13.5 psi. Until I figure out how to avoid boost creep it will remain off.
Old Feb 24, 2004 | 12:41 PM
machinis's Avatar
Boricua
Wow! Back from the death again. I am having the same problem, but on an FD. Anyone has any suggestions/solutions? I have check all the connections twice, even soldered the cables. One thing I noticed is that my cruise control doesn't work properly on anything over 60Km/H but my speedometer works perfectly.
Old May 28, 2012 | 11:15 AM
hiroichi1515's Avatar
Has anyone fixed this issue yet and just decided not to share? You have been resurrected thread!!!!
Old May 28, 2012 | 11:19 AM
misterstyx69's Avatar
Retired Moderator, RIP
Just an Idea.
Wouldn't using a Abs sensor on the front wheel give you speed?.That is,IF you disconnected the ABS already and just have the sensors sitting there doing nothing.
Old May 28, 2012 | 11:39 AM
RotaryEvolution's Avatar
Sharp Claws
only reason you need the speed sensor is for gear judge and auto learn, which in itself doesn't really work that well anyways.
is it worth it modifying the car to get the signal to the AVCR? no.
Old May 28, 2012 | 02:50 PM
I want to use gear judge for start duty for each gear. My car does have abs. Gonna try changing out the cluster. New speedo cable, replacement transmission, same issue. Thanks for the response.
Farkel
Sep 16, 2015 06:16 PM
