Funky Idle Mojo
Old Oct 6, 2002 | 10:45 AM
V8what?!'s Avatar
bov ftw
Funky Idle Mojo
I have an 89' TII with some funky idle mojo. When I start the car cold, the enigine won't idle. Once the motor has warmed up, it will idle, but it only idles around 750rpm (and sometimes a little lower).This problem has become incresaingly worse. At first, cold starts just had a little trouble idling, but now they won't idle at all. Is this a typical tps or bac problem? Any input would be greatly appreciated.
Old Oct 7, 2002 | 02:09 AM
V8what?!'s Avatar
bov ftw
bump!
C'mon, somebody out there knows what's going on here?...or at least can ask questions to figure it out.
Old Oct 7, 2002 | 10:36 AM
Rotorific's Avatar
I dont know a damn thing
first off the engines idle is supposed to be 750 on the dot do you have the tb mod??? you could also adjust the idle adjust screw on top on the tb to adjust your idle higher so it doesnt dip below 750
Old Oct 7, 2002 | 04:32 PM
Spawn VII's Avatar
so what effect does it have on idle if you did the tb mod? besides the cold start, i didn't think it will affect the idle
Old Oct 8, 2002 | 07:22 PM
V8what?!'s Avatar
bov ftw
I don't have the tb mod, but the point is that it won't even idle when I first start it. I have to keep pressing the gas [and drive it around] until it heats up. Does this sound like anything anyone can point out?
Old Oct 8, 2002 | 07:37 PM
dragondwc777's Avatar
Sounds like your throttle plates for your fast idle is out of spec or thermowax bad/stuck
Old Oct 8, 2002 | 08:03 PM
V8what?!'s Avatar
bov ftw
Old Oct 8, 2002 | 08:46 PM
Haynes manual???
Old Oct 8, 2002 | 10:28 PM
Choey's Avatar
i also have this problem slightly
i just tap the gas once its started and then it idle's fine
Old Oct 9, 2002 | 06:08 PM
V8what?!'s Avatar
bov ftw
Yeah, I've got the Haynes Manual, but I'd rather be able to identify the problem than search for it first. What's thermowax a part of?
Old Oct 9, 2002 | 09:11 PM
thermowax control the fast idle cam when it heats up the cam moves and controls your throttle plates clearance inside your intake. iI is basically your choke. It is located on the back of your intake it is a white valve with 2 hoses on it the Haynes manual explains how to see if it is working.
Old Oct 17, 2002 | 11:41 AM
V8what?!'s Avatar
bov ftw
Finally started tearning things up again, even bought an ohmmeter, but the problem was simple. The little elbow that leads to the bypass valve had a HUGE crack in it. I had checked for leaks about two weeks ago, but now that sucker's obvious. The Turbo XS bov is a damn tight squeeze to fit in that elbow. I threw on a temporary solution until I can make it to autozone.
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
93FD510
Oct 1, 2015 02:00 PM
Jmpabon93
Sep 30, 2015 04:57 PM
