HELP. i broke my rear end
Old Oct 6, 2002 | 01:52 AM
zooq's Avatar
i was at the track (using BFG drag radials) and i launched my car at 6k and the car didn't move. i towed it to a performance shop in town and it looks bad.
where can i buy a high performance rear end?
i know that the casing broke because we were abel to pick some of the teath off the track. and will that Kaaz differential replace everything?
thanks
Old Oct 6, 2002 | 03:26 AM
zooq's Avatar
and where can i buy a cheap housing from?
i think i'll need a Housing/ring and pinion/ and also the Kazz or Cusco diff.
Old Oct 6, 2002 | 08:17 AM
streetdreamzny's Avatar
i broke my rear at the track too. the kazz rear doesn't come with everything just the lsd like you said you also need the ring and pinion. if you drag race alot you should change the gears to 4.30 while everything is apart . expect to pay around $880 for the kazz and $500 for the gears
Old Oct 6, 2002 | 02:41 PM
zooq's Avatar
what about the case (round looking thing) ? how much is that?
Old Oct 6, 2002 | 07:02 PM
zooq's Avatar
come on guys, some info please
Old Oct 7, 2002 | 12:40 AM
zooq's Avatar
is this turning into the supra forums, no one is friendly enough to help me?
Old Oct 7, 2002 | 07:03 AM
i'm not sure how much the case is because i didn't have to replace it, but i would figure it would be cheap. check around on the web for a used one. your looking at around $550 just in labor to get all the parts installed
Old Oct 7, 2002 | 07:16 AM
allrotor93's Avatar
link
Rotor Motorsports
Old Oct 7, 2002 | 07:38 AM
Fd3BOOST's Avatar
Recovering Milkaholic
get the cusco limited slip. I think it is gonna run you anout $1k new but it has everything you need. Not sure where to get it though. try
www.rx7.com
www.mazdatrix.com
Old Oct 7, 2002 | 07:46 AM
RedFD's Avatar
"inukai" from the forum can get you a good deal on a cusco. Thats where I got mine.
Th0m4s
Feb 26, 2019 02:04 AM
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
