my vac system.
Old Oct 4, 2002 | 05:50 PM
SLOWT2's Avatar
From: new hampshire, middleton(a town so small we have no conveince stores)
my vac system.
this is a diagram, of my compleate vac system., there is only 8 vac lines and 2 fuel lines, if you have any question about it just post a reply and i will tell ya all about it.
Old Oct 4, 2002 | 06:00 PM
HAILERS's Avatar
HAILERS
I seriously do not think one should use the nipple b/t the two oil injectors for fuel pressure regulator regulation. I could of course be wrong.
Only way I know to be sure is to put a boost gauge on that line and see what the max boost coming off that nipple is. It goes to the fuel injector air bleeds.
Old Oct 4, 2002 | 06:09 PM
SLOWT2's Avatar
the line between the 2 oil injectors goes to the side of the dynamic chamber, the vac feed for the fpr comes off of the dc also.
Old Oct 4, 2002 | 07:40 PM
HAILERS's Avatar
HAILERS
Oh, forget what I just erased... Looked harder at your diagram. I see what you mean. Sorry 'bout that.
Old Oct 5, 2002 | 08:52 AM
SLOWT2's Avatar
common you guys are always asking about vac problems well here is one of the most simplist vac system you can get. less vac lines less change for a leak.
Old Nov 22, 2002 | 05:24 PM
600HP CLUB's Avatar
there is a nipple located on the lower intake manifold, what did u do with it? did u block it?
Old Mar 27, 2003 | 12:02 PM
Moxeys93RX7's Avatar
why do you still have the bac on there?
Old Mar 27, 2003 | 07:03 PM
Pinfield357's Avatar
can you do that and still pass emisisons testing?
EDIT: is the air bypass valve (BOV) vac line going into the BAC or into the nipple just under it?
EDIT II: nm there isnt a vac line on the BAC
Old Mar 27, 2003 | 07:16 PM
AreExSeven's Avatar
Huh?
So have you tested this setup or is it just a theory? I'm looking for a real simple setup to use for mine.
Old Mar 27, 2003 | 09:56 PM
Scott 89t2's Avatar
SOLD THE RX-7!
haha here's mine. I kept a few more then you
http://www.1300cc.com/UIM/plans.jpg
lotsa pics
Old Mar 27, 2003 | 10:12 PM
AreExSeven's Avatar
Huh?
lotsa pics
Did yours end up working correctly?
Also, what is the purpose of the oil catch can?
Old Mar 27, 2003 | 10:13 PM
Scott 89t2's Avatar
SOLD THE RX-7!
well it runs
to catch oil comming from the oil fill tube. stop it from being sucked into the turbo.
Old Mar 27, 2003 | 10:19 PM
AreExSeven's Avatar
Huh?
well it runs
Ah, I didn't notice it went to the oil filler neck. Is it possible to just cap that line off instead?
And I guess running is better than where I'm at right now...
Old Mar 27, 2003 | 11:35 PM
Scott 89t2's Avatar
SOLD THE RX-7!
nope you can't block it off. some just put a little K&N breather filter on.
Old Jul 19, 2004 | 10:38 AM
baddassTurboII's Avatar
Scott , how well does it run?
Old Jul 19, 2004 | 11:13 AM
ddub's Avatar
i am legendary
I have 2 vac lines total in my n/a, works very nicely. Not much chance for a leak with 2 vac lines and every other nipple capped
Old Jul 19, 2004 | 12:38 PM
BTW did you use rubber fuel hose? of did you still go with the metal hoses under the intake manifold?
Old Sep 22, 2006 | 08:50 PM
Richter12x2's Avatar
Taste great, more filling
Am I missing something? I never saw a diagram here. The links to the diagrams at 1300cc are gone, too. :P Does anyone still have this lying around? (Yes, I know it's old)
Old Sep 23, 2006 | 03:17 AM
stevej88na's Avatar
Strength and Honor
Judging form your avatar you have an n/a; check this link. S4 and S5 should be very similar.
Old Sep 23, 2006 | 10:46 AM
Sweet, that may have something to do with it. I never really distinguished between metered air and vacuum, so it's possible I've got some weirdness going on there. :P It's just weird that it would run for hours before I fixed my exhaust leak, and now it won't even idle.
alexdimen
20
Oct 23, 2015 01:50 PM
RuffRx7
Oct 1, 2015 03:08 AM
