a silver tube that says NF1 on it is that a check valve aswell?
Old Oct 3, 2002 | 04:04 PM
there is a silver coated tube that is attached to a vacuum hose. it says NF1 on it and it runs to just inside of the manifold, now is that a check valve or what is it? because i noticed oil or greasy stuff on the outside of assuming its a check valve that it may be leaking, and that could also be whats causing my boost problem.
Old Oct 3, 2002 | 04:26 PM
Mahjik's Avatar
Mr. Links
There is an aluminum check valve on the front side of the UIM (toward the front of the car). However, it's used in the purge control system. That valve shouldn't effect boost patterns/levels.
Monsterbox
Jul 29, 2022 10:48 PM
HDA
Nov 3, 2015 03:49 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
rotor_veux
Sep 3, 2015 07:10 PM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
