Sponsored by: CARiD
Question for you rotorheads
Old Oct 3, 2002 | 10:59 AM
Question for you rotorheads. I looked under the car and noticed gaps where the gaskets are between the turbos and engine. Looks like the manifold not even. Can you resurface (grind) the manifold? Would that cause a major vacuum leak? And would it make the car stumble past idle?
Rob
Old Oct 4, 2002 | 01:59 AM
duboisr's Avatar
The manifolds (allmost any) can be resurfaced by machine or by hand (if you know how , a long time to do ) ,a leak in this area will be an exhaust leak not a vacuum leak and you should hear it .
Old Oct 4, 2002 | 05:16 AM
Thanks!
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
