What happen with my $%&# clutch?
Old Oct 3, 2002 | 09:42 AM
RexTech's Avatar
Exclamation What happen with my $%&# clutch?
Hi guys, I changed the clutch of my 1987 N/A RX when I replace the engine,when the work was finished I noticed that the pedal was down and the pressure was not enough so I decided to change the master and slave cilynders too, I bleed the system many times and there is no enough pressure and the pedal still so low, I can change the gears but with trouble.
What the &$%/& is going on?
Could be a problem with the installation of some components? -release bearing, pressure plate or disc-
Thanx for your help, RT.
Old Oct 3, 2002 | 10:33 AM
biorotary's Avatar
have you checked the clutch pedal height?
at one point i was having a similar problem and it turned out to be that the pedal height was off...so check that...
Old Oct 3, 2002 | 04:44 PM
Silkworm's Avatar
Has been.. hangin' around
benchbleed the master cylinder first. If you haven't done that, it doesn't matter how many times you try to bleed the system, you'll never get all the air out.
PaulC
whinin
Mar 30, 2019 07:53 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
risingsunroof82
Sep 9, 2015 08:06 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
