What's lighter??
Old Oct 3, 2002 | 01:54 AM
DJ!
Question What's lighter??
Whats lighter a 12a waterpump?? or series 4-5 waterpump??? and im talking bout the whole thing the housing and the pump. thanks
Old Oct 3, 2002 | 08:54 AM
Rx7carl's Avatar
Airflow is my life
2nd gen has an aluminum housing.MUCH lighter. Not a straight bolt on though.
Old Oct 3, 2002 | 09:37 AM
Pele's Avatar
Right near Malloy
How ya gonna put a 13B water pump housing on a 12A... Aside from weight, is there any other improvement?
Old Oct 3, 2002 | 12:06 PM
Redwood's Avatar
Find Racing
Provided you're upgrading your water pump anyway, you might as well just drop a bit more and get rx7heaven's (or something like that, do a search) electric setup. It saves weight (like 7 lbs) and it won't cavitate at high rpm's.
Old Oct 3, 2002 | 04:58 PM
Rx7carl's Avatar
Airflow is my life
It fits with minor modification. Mine's not done but others have done it already. Usually you relocate the alt to the air pump position, another favorable weight shift!
Stock assy= 14lbs
Alum+alum water pump=6 lbs, saving weight up high and that far forward will help handling.
Old Oct 3, 2002 | 04:59 PM
Rx7carl's Avatar
Airflow is my life
And your wallet would be lighter too!!!!!
Old Oct 3, 2002 | 05:59 PM
RotorMotorDriver's Avatar
Seven Is Coming
What exactly is cavitation anyway? I know its bad, thats why you try and avoid it, but what is it? I assume from the word "cavity" that means hole, that maybe "cavitation" is the forming of holes in the water...a.k.a. bubbles? Im not sure though...Am I close?
~T.J.
Old Oct 3, 2002 | 06:23 PM
Defprun's Avatar
Punk Ass Bitch
Your wallet may be lighter...but it will be alot lighter if your car blows up
Old Oct 3, 2002 | 06:36 PM
Manntis's Avatar
add to cart
yup, cavitation is bubbles, basically when a pump is churning water rather than moving it because it's spinning too fast.
Old Oct 3, 2002 | 09:38 PM
Pele's Avatar
Right near Malloy
Stock assy= 14lbs
Does 8 Lbs really make that much of a difference?
Any way to keep the alternator in it's existing location or move the air pump and keep it? (Emissions legality)
Old Oct 4, 2002 | 06:41 AM
Rx7carl's Avatar
Airflow is my life
Can you clarify that when you sober up? WTF are you trying to say? Your not making sense.
Old Oct 4, 2002 | 06:45 AM
Rx7carl's Avatar
Airflow is my life
In racing.....ABSOLUTELY! street? prolly not.
I belive you could retain the stock alt location, just takes more work. With the 2nd gen pump and housing, you lose the bolt location for the alt adjusting strap mount. SO if you can come up with a way to mount the strap, then youd be good to go!
betes
Sep 27, 2015 08:25 AM
