Which ECU's are interchangeable?
Old Oct 1, 2002 | 11:17 PM
TRURX7's Avatar
I was wondering which ECU numbers are interchangeable. I have gathered that TII ECU are not compatible with NA ones, but I would like to know which numbers can safely be interchanged if any.
Thanks in advance.
TRU
Old Oct 1, 2002 | 11:26 PM
TonyTurboII's Avatar
Glock Lover
ECUs are interchangible with other ECUs with the same first 2 numbers.
Example: N-xxy As long as the Two ECUs have the same "xx" the "y" doesent matter.
Example 2: N-352 would be interchangible N-355. I dont know if those are real ECU numbers, but you get the idea.
Ive also heard some of the Convertible models had ECUs compatible turbos.
Old Oct 1, 2002 | 11:44 PM
TRURX7's Avatar
damn that sure helps.. thank god i took algebra class
BUSTN
V-8 Powered RX-7's
Sep 2, 2015 04:39 PM
