turboxs mbc question,about gauge?
Old Oct 1, 2002 | 07:47 PM
Unhappy turboxs mbc question,about gauge?
I was wondering if any of U that have used a turboxs mbc w/the stock gauge in an 88t2 or did U have to install a aftermarket boost gauge to get a good reading for up to 12psi. Please help.
THANX, in advance.
Old Oct 1, 2002 | 07:54 PM
TonyTurboII's Avatar
Glock Lover
Do you have any other modifications? Im a firm believer that guages should be your first mod.
Old Oct 1, 2002 | 08:02 PM
yep!
I have a 2.5dp ,mp,catback system. I have RB fcd, apex race filter intake kit, turboxs typeS bov. crane hi 6 ignition. My ques. is can I use my stock gauge or do I have to install another. And should I "T" in at the side of the bov that goes into upper intake for the best reading.
thanx, TONY
Old Oct 1, 2002 | 08:08 PM
Glock Lover
Many, many people her will agree with me, the stock guage is a useless piece of ****. After many reccomondations, I T'd mine in the pressure sensor line.
Old Oct 1, 2002 | 08:16 PM
So, I guess what your saying is yes get an aftermarket! And thats what I thought about the pressure line,but someone was telling me to T into the bov.
Thanx
Old Oct 1, 2002 | 08:19 PM
Glock Lover
I think, that it would be ok to T in there too.
Old Oct 1, 2002 | 08:29 PM
Scott 89t2's Avatar
SOLD THE RX-7!
you MUST MUST MUST MUST buy an aftermarket gauge.... should have been the first thing you bought. the stock one will never go past 8psi with the FCD installed. even if you are way past.
Old Oct 1, 2002 | 08:37 PM
where on gauge
My biggest problem is once I put the boost control on how do I know how much I am getting,b/c it is ajustable.Where on an autometer gauge is about 12psi located. sorry for stupid ques, first time messing w/boost.
Old Oct 1, 2002 | 08:55 PM
Scott 89t2's Avatar
SOLD THE RX-7!
well when the gauge gets to 12psi... then the controller is at 12 LOL... unless you were aready creeping to 12 before hand.
Old Oct 1, 2002 | 09:06 PM
O.k. ha ha j/j I was just saying that I don't know how to read the gauge with all that 1bar stuff, b/c I've never messed w/the boost before. thanx,scott
Old Oct 1, 2002 | 09:11 PM
inboost's Avatar
Looking at the wiring diagram it seems that the factory boost gauge is tapped into the pressure sensor's line to the engine computer. I was thinking the following:
Have one of these indiglo gauge guys make a stock looking boost gauge but scale it in PSI starting with 0 PSI where the stock gauge currently reads vacuum
Now disconnect the factory gauge from the harness and connect it to another pressure sensor. With a little signal conditioning (voltage comparitor ckt) we could have the factory gauge showing us boost to say 15psi over a sweep of 90 degrees (no longer shows vacuum).
Doesn't seem too tuff, does it?
Old Oct 1, 2002 | 09:32 PM
Ryde _Or_Die's Avatar
I believe 1 bar is just about exactly 14.7psi. So figure it out from there. Or do a search, cause people talked about it before.
