Stumbling like S**T!!!!!
Old Oct 1, 2002 | 11:26 AM
osiris7's Avatar
Angry Stumbling like S**T!!!!!
hi all,this is the problem, i have a 87 N/A ran great and had the normal 3800 rpm stumble but didnt bother me..now it stumbles going up to the 3800 rpm..fuel filter was changed Tps is set, im thinking the grounds are probably bad,could someone shed some light on the subject and let me know where the grounds are??thanx in advance..
Old Oct 1, 2002 | 11:49 AM
PraxRX7's Avatar
well..
I found that re-wiring the fuel pump tends to help, took me 13 hours though. You might want to try the re-wire, it might help you out (also if you do the re-wire, pick up some redline fuel injector cleaner...its good stuff!)
check out the fuel pump re-wire walkthrough on
http://www.1300cc.com
Old Oct 1, 2002 | 01:19 PM
FEDREX's Avatar
"Just Looking".......
check your plugs.
Old Oct 1, 2002 | 08:10 PM
osiris7's Avatar
thnaks guys, let me try these things and see what happens..
Old Oct 2, 2002 | 10:45 AM
osiris7's Avatar
ttt
rgordon1979
40
Mar 15, 2022 12:04 PM
alphawolff
Nov 17, 2015 05:57 PM
Jmolina0163
19
Sep 25, 2015 06:06 PM
R7rexy
19
Sep 2, 2015 10:24 AM
Kruel13
Aug 26, 2015 12:17 PM
