Where do the antirattle springs fit?
Old Oct 1, 2002 | 07:35 AM
85gs's Avatar
On the 84 GSL-SE front brakes, where does the anti-rattle spring fit? Neither the Haynes nor the Mazda manuals show where they actually go. One fell out and the other was jambed against the back of the caliper when they were removed.
Old Oct 1, 2002 | 07:23 PM
85RX7GS's Avatar
Anti-rattle? My ReX needs a lot of anti-rattleness.
Old Oct 1, 2002 | 07:27 PM
S2-13BT's Avatar
You'll see holes in the top of the pads. The little length of the anti rattle spring fits in there. If I remember correctly, you start in a hole on the pad closest to you and in the lower hole. The pads should have 2 holes each, so it doesn't matter when you put them in. Then it will only go one way.
I hope that actually makes some sense!
If not I'm sure someone else will explain it alot better than me.
Old Oct 2, 2002 | 05:34 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
In the garbage can, just get some of that stop squak, its a silicone derivative. You spread it even on the metal part of the pad, and it sticks to the caliper, keeping the pad from rattling, and then causing squeaking..
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
kkev.7788
Sep 2, 2015 01:32 PM
