can i run 10 lbs on the stock wastegate?
hey guys i've been told that at about 10 lbs i'll get spikes without portinig the wastegate.... is it necesary or is it just a rumor?
Re: can i run 10 lbs on the stock wastegate?
I'm not sure what you are talking about. if you are running 10psi with the stock wastegate that is fine. the problem is adding an exhuast will put you to 10 psi. and there is no way to lower it.
I'm not sure people understand what a wastegate does. Porting your wastegate will not cause boost spike or boost creep and it will not make you run at 10psi. The wastegate vents excess exhaust gas, porting it makes it bigger there for allowing you to vent more gas. I think a search of the forum on the purpose and function of the wastegate might be in order.
Trending Topics
with my Profec-B i ran 10 psi on my S5, No problem. If you have other bolt ons you will notice that the stock turbo will have some difficulty maintaining that pressure at high RPM's in the upper gears. Especially if your turbo has high miles and is stock. porting the waste gate allows better control of the boost curve (rise).
I have 88 tii, get 10psi in 1st, 9 psi in 2nd, 13 psi in 3rd. Only major mod I have is a 2.5 inch exhaust from turbo to muff. I also removed egr. That's it. I get no boost creep or spikes what so ever.
RCCAZ 1
Aug 11, 2015 07:05 PM
