That anoying buzzer
Old Sep 30, 2002 | 10:11 PM
USNALAX1's Avatar
Lightbulb That anoying buzzer
Hey does anyone know where the buzzer is located the one that goes off when your coolant is low. cause i ordered a new sensor but i can't stand that sound anymore so i'm just going to disconect the ground. if you know where where it is please let me know i don't feel like hunting for it!
Old Sep 30, 2002 | 10:19 PM
koukifc3s's Avatar
Clogged cat
The sensor is in the middle of your radiator, just disconnect it.
Be sure to check your coolant level regularly though.
Old Sep 30, 2002 | 10:51 PM
RexRyder's Avatar
yea jus disconnect that wire thats in the middle of ur rad
Old Sep 30, 2002 | 11:10 PM
SUPRAMAN
my 87 used to do that i hated it
Old Sep 30, 2002 | 11:38 PM
Silkworm's Avatar
Has been.. hangin' around
Disconnecting that wire should send the buzzer into a frenzy. You need to GROUND that wire.
Alternately, you could get a new sender, to fix your problem.
Or you can unsotter the buzzer from the instrument panel.
PaulC
Old Oct 1, 2002 | 12:02 AM
Slammedblk7's Avatar
Yes its slow
ground the wire onto the car metal...works great...
Old Oct 1, 2002 | 11:27 AM
USNALAX1's Avatar
hey Slammedblk7 have you done it before, cause i don't want anything to short if i do ground that wire.
and also i know where the sensor is but what i need is to find the buzzer that goes off when the sensor is unpluged so i can unground the sensor!
Old Oct 1, 2002 | 11:34 AM
Piranha's Avatar
what 7
I don't understand why you don't fix it; this sensor has saved me from ruining my engine. One of my hoses busted, and a little revving wouldn't make it go away, so I pulled over and saw I was leaking, bigtime. Turned off the car and got a new hose.
Old Oct 1, 2002 | 03:12 PM
USNALAX1's Avatar
i'm getting a new sensor but i have to go for a week with out it. so i need to kill this crazy buzzer!
Old Oct 1, 2002 | 03:19 PM
Piranha's Avatar
what 7
ah, that makes sense
c0rpse
16
Sep 25, 2015 11:33 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
86glxNA
Sep 15, 2015 04:20 PM
The1Sun
Sep 7, 2015 10:21 PM
