Is there such thing as TOO thick of a radiator?
Old Sep 30, 2002 | 02:46 PM
AreExSeven's Avatar
Huh?
I was thinking of getting the Koyo Radiator which is 53mm thick. Will this radiator cause a problem with pulling air through since it is so think?
I do have the perma cool 16in electric fan to go with it.
Old Sep 30, 2002 | 02:48 PM
RETed's Avatar
Yes, too thick just adds weight with very little cooling benefit for street cars.&nbsp Stick with 2-row radiator cores and you should be fine - these are usually around 2" - 2.5" thick cores (like yours).
-Ted
Old Sep 30, 2002 | 02:51 PM
AreExSeven's Avatar
Huh?
Sweet, thanks
Old Sep 30, 2002 | 03:00 PM
Rpeck's Avatar
What R U thinking self?
I have the Koyo in mine and its the ****! do a search if youy want to see pics.. I posted Pics of mine all installed. Did you get that thing fired up? (your car)
Old Sep 30, 2002 | 03:06 PM
maxpesce's Avatar
Ex fd *****
53mm = 2.1" which is not too thick
Yes the thicker the radiator the harder it is to get air through it the Practical limit is 3 row/ 2.5" after that the efficiency falls off because the air won't flow through, it just stagnates in the core.
Old Sep 30, 2002 | 03:08 PM
AreExSeven's Avatar
Huh?
I did!
Look in my sig.
Radiator is the last thing I need.
Almost drove it to Sevenstock, except for the leak (and its a bad one).
Did you end up taking the AE? I looked for one with a black engine bay, but couldn't find it.
Old Sep 30, 2002 | 03:12 PM
Rpeck's Avatar
Nope, I didnt go... I took 3 days off work last week cause I had the worst cold of my life! I was sicker than **** most of the weekend, i will have to make it next year. I did drive the AE to work today though And i got my S-AFC & A/F meter installed this weekend. I still need to bump the idle down a little bit ... otherwise its running like a dream, DMV gave me a one month permit to break the motor in and get it smogged .. so I am racking up all the miles I can .... and loving it!
Paint job commin up in a couple of weeks then its totally done.
Old Sep 30, 2002 | 03:15 PM
RETed's Avatar
Upgrade radiators are one of those things that are usually overlooked - like (EGT) gauges.&nbsp If you can afford one, I'd highly recommend getting one - you'd be surprised how inadequate the stock unit is, especially for a turbo.&nbsp Excess cooling can never hurt!
-Ted
Old Sep 30, 2002 | 03:16 PM
AreExSeven's Avatar
Huh?
Just ordered it
Be here in 2 days I think.
Old Sep 30, 2002 | 03:19 PM
Rpeck's Avatar
-Ted
I agree. With all my mods I forced myself to not even start the car untill my radiator was installed, I didnt want to risk anything with a new rebuild. ...
P.S. I havent seen the heat get over 1/4 infact usally less than that, even if I let it idel for a long *** time
streetlegal?
Mar 17, 2022 02:46 PM
sandy_RE
Interior / Exterior / Audio
Sep 24, 2015 10:37 PM
Kruel13
24
Sep 16, 2015 09:08 AM
djritz
Aug 25, 2015 02:46 PM
