85 RX7 Gas Gauge Problem
Old Sep 30, 2002 | 11:46 AM
Nandino's Avatar
Hi Everyone
Im having a problem with my gas gauge..All of a sudden the gas gauge, goes from FULL and sweeps slowly down to EMPTY, and then it might Sweep slowly up to HALF , or FULL and then sweep back to EMPTY keeps doing this.
Its a lil annoying since I cant tell how much gas I have left..Anybody else had this problem, can you please advise on how to fix this
Thanks
Old Sep 30, 2002 | 12:26 PM
CrazyJoe12a's Avatar
I have the same problem with my 82. Saw a write up on how to adjust the sending unit and tried it, but it still does it. I'm stumped
Old Sep 30, 2002 | 12:32 PM
DONNA's Avatar
had the problem till i removed the rust off the fuel level sender in the gas tank,,no big job, just be carefull cleaning the very small wire windings,,,,,
Old Sep 30, 2002 | 06:10 PM
85RX7GS's Avatar
This happens to me too, although when it's FULL, the gauge still reads EMPTY until I start driving it. Then it'll move up to HALF and jump around...I had the sender out and was manually operating the float, but it wouldn't move the gauge....bad ground?
Old Sep 30, 2002 | 07:21 PM
WackyRotary's Avatar
standard combustion
There is a variable resistor in the sender unit in the tank. It can go bad, but rarely does. THe most likely clulperate is the wire connector on the tank, corrision and rust. Spray with WD-40 and scratch up the connector on the tank and try it then. If its still acting up be sure your wires are not corroded. It CAN happen with wires that look fine and water gets in a tiny hole. A give-away is a very brittle unflexible wire.
Finally as mentioned above the sender unit may need to be taken out and replaced or cleaned up on the variable resistor.
Old Sep 30, 2002 | 08:32 PM
680RWHP12A's Avatar
change out the fuel sender with a new one, it will work like new! thats all you need to do....
Old Sep 30, 2002 | 09:02 PM
coldy13's Avatar
Yeah, shutup kid.
Mine moves around +/- 1/8 from the actual level of gas. Doesnt bother me at all though, when it gets down below 1/4 it stops and gives me the right reading all the time.
Old Oct 1, 2002 | 08:52 AM
85RX7GS's Avatar
I think that there is also a little bit of play where the arm moves along the resistor. That could account for the spontanious readings that I get, as I hit a bump.
Rotospectre
Mar 28, 2018 03:33 PM
gtcd
30
Aug 19, 2015 02:44 AM
