Have momo wheel, can't see tach! Anyone else?
Old Sep 29, 2002 | 03:33 PM
Redwood's Avatar
Find Racing
Angry Have momo wheel, can't see tach! Anyone else?
I installed a momo 350mm wheel a while ago and now I can't see my tach or speedo. I'm just wondering if anyone has had this problem or if my steering column needs to be lifted a little (I have a custom adjustable steering column bracket). Thanks.
Old Sep 29, 2002 | 03:40 PM
WackyRotary's Avatar
standard combustion
I know someone with a Momo wheel. I personally don't like them because they do just as you discribe, block the view of important gauges(speedo, tach). No one, to my knowledge has any adjustable steering on a 1st gen. Sucks to be you. Best solution to me, get the stock wheel back on.
Old Sep 29, 2002 | 03:45 PM
Defprun's Avatar
Punk Ass Bitch
I have a solution....give me the wheel! I'll take it off your hands (literally). It will give me a reason to get aftermarket guages.
Old Sep 29, 2002 | 04:43 PM
rx7 Nut's Avatar
I couldn't even see the top of the speedo when I had my stock se wheel on. Then I got a gxl wheel and seats and I can see fine. Try lower seats I guess, but that wheel might still be to small.
Old Sep 29, 2002 | 05:18 PM
standard combustion
Really? How much lower are your seats? I NEED that, I'm a tall man and hate what head clearence issues I've put up with over the years?
What seats are you using? Are those cloth or leather.
Old Sep 29, 2002 | 05:46 PM
Manntis's Avatar
add to cart
I'm 6'1" and find that leaning the seat back or adjusting the up/down rake of the lower cushion (is that an SE only feature?) solves any head clearance or instrument visibility issues
Old Sep 29, 2002 | 05:59 PM
Defprun's Avatar
Punk Ass Bitch
Some people may not like lying down when they drive. I like a straight-up rally style sitting position while i negotiate turns in my vehicle
Once I layed back a bit on the highway, and i actually fell asleep i was so comfortable and hadnt remembered seeing the exit that the sign had just announced...lucky it wasnt my exit.
Old Sep 29, 2002 | 07:05 PM
standard combustion
I have that delema. I really don't leaning way back and tilting my head forward to sit. Although this is a semi-relax'd position, its not a good position for most driving situations were I like to be fully alert and since the position discribed above seems to lead me to fatigue and sore back/other things. The lumber support is a joke almost. Yeap, I have the same seats, GSL has all that.
As for racing situations which require a helmet, F*CK!! I can't drive it without the moonroof fully extended and the seat moved forward some so I can tilt it back even further so I can move my head freely. I'm 6'3" ~175lbs but I can fit my knee's just fine compared to simliar people my height. So seat being farther ahead isn't really a issue.
My '88 is great, the seat can be fully up and still have ~3" of space above me with the moonroof closed!
This is my #1 complaint of 1st gens WITH OUT DOUBT.
So if anyone in MN has 2nd gen red cloth seats for sale cheap, give me a ring
Old Sep 29, 2002 | 07:25 PM
Directfreak's Avatar
I am a Jeeper Now.
a glass top also gives you more head room.
Old Sep 29, 2002 | 07:38 PM
Redwood's Avatar
Find Racing
I have second gen seats in my 85, but I'm still sitting too high. I will NOT be putting the stock wheel back on as it's so nice to hand a small wheel on this tossable of a car. Sitting upright really makes a difference in the way I drive too, so I'll be not changing that.
Anyone know if the Corbeau Forza sits any lower than a stock seat? I have a feeling it wouldn't since I'd be upright still.
Perhaps custom seat rails? Anyone done this?
Old Sep 29, 2002 | 07:42 PM
I am a Jeeper Now.
I'll let you know soon. I have ordered custom "low" seat rails and sliders for my Recaro's.
BTW, I have a Momo steering wheel, and it does block the view slightly, but..
It it is OH SO WORTH IT!
Old Sep 30, 2002 | 08:30 AM
MyRxBad's Avatar
EliteHardcoreCanuckSquad
PM Silverrocket. He has a Corbeau seat in his first gen.
Old Sep 30, 2002 | 08:55 AM
David88vert's Avatar
r71's daddy
I had Corbeaus, still were to high. Now I run a 340mm steering wheel, and a Momo racing seat. It sits me a lot lower.
