S-AFC Question
Old Sep 28, 2002 | 11:15 PM
silverrotor's Avatar
S-AFC Question
Little confused on what Hi and Low Throttle position feature to put Into the S-AFC. What are Its functions exactly? Is It a standard number? Some details would be great.
Old Sep 29, 2002 | 12:02 AM
Cheers!'s Avatar
Former Rx7 *****
"They are used by the S-AFC to calculate fuel corrections at various TPS readings (throttle positions) at each RPM. At TPS settings below the Lo-Thrtl point, fuel corrections are constant - this is good for letting the ECU operate properly in closed-loop mode. At TPS settings above the Hi-Thrtl point, fuel corrections are also fixed - good for compensating for a throttle pedal that doesn't go as high as 100% (such as caused by thick carpeting or floormats). At TPS settings in-between the two, the S-AFC always calculates a correction proportional to the Lo-Thrtl and Hi-Thrtl numbers. Close to the Lo-Thrtl point, the correction will be more like the Lo setting at that RPM; while close to the Hi-Thrtl point, the correction will be more like the Hi setting at that RPM."
http://wac.addr.com/auto/obs/safc/safc.html
Old Sep 29, 2002 | 12:10 AM
Cheers!///I'm dumbfounded. Beautiful.
Old Sep 29, 2002 | 11:15 AM
Aaron Cake's Avatar
Engine, Not Motor
You have a S4, so set the low throttle to 93%, and high throttle to 94%.
Old Sep 29, 2002 | 11:39 AM
Yea but couldn't the throttles be set on zero, for example. That way the S-AFC Is making fuel adjustments allthroughout the throttle position. By doing It this way you are maximizing (customizing) the piggyback to work according to what you Input at rather than having any fixed points?
Old Sep 29, 2002 | 11:40 AM
Besides, didn't you adjust my hi and lows to 10 and 90 the other day?
Old Sep 29, 2002 | 02:11 PM
Aaron Cake's Avatar
Engine, Not Motor
The TPS on the S4 is not full range...ie. 100% on the TPS is about 1/4 throttle. So you want to set the S-AFC so that anything less than 1/4 throttle is "low", and anything more is "high". It's not the best solution, but it's the only solution besides swapping in the 89+ TPS (annoying).
Old Sep 29, 2002 | 02:59 PM
wpgrexx's Avatar
so why would uou say 94%, why not go 98 and 99%, than for sure it is hi past 1/4 throttle . just wondering what the difference is?
Old Oct 11, 2002 | 08:34 AM
Old Oct 11, 2002 | 10:56 AM
DaleClark's Avatar
RX-7 Bad Ass
Wow, that Subaru site is really good!
BTW, I don't recommend the "blue wire" mod - DSM'ers have proven that it can load the output of the O2 sensor a bit and cause false readings.
Dale
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
